The hook on the rod that goes through the frame. This rod has the clutch pedal attached to the outboard end. The hook is on the inboard end and hooks through a hole in the stirrup to actuate the clutch. On my 55 it is jumping out of the hole in the stirrup. Any good ideas on what is wrong?
I had to replace the yoke in mine when I added the front Disc brakes, but the old one had a couple spacers and a spring that held everything in place. I also had to replace the Shoulder bolt that went between the yoke and transmission bracket because it was worn out. Check out Mid Fifty Catalog page 166 for parts.
Been trying to assemble our truck from a pile of parts and was scratching my head for quite a while...I'd agree with Indy or suggest a drilled hole with a cotter and washer to keep it located where it should be....But that's my shadetree mechanic talking, not my restorer.
Ordered one of each.. Think it is the first time I have ordered from Mid Fifty. Will NOT be the last. That is the most user friendly on line part catalog I have ever used.
