8.8 Gear Swap & Install Kit
Old 09-04-2016, 09:37 PM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I am going to be installing 3.73 gears and a traction lock in the F150 sometime soon. I am open to any tips from anyone that has done this before. I am also shopping around for a complete install kit with bearings, seals, shims, marking compound etc. Does anyone have any suggestions for this?
Old 09-04-2016, 10:23 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is offline
Received 1,345 Likes on 1,062 Posts
Have you checked with Reider and Randy's for installation kits? They didn't have kits where you got the ring and pinion and LSD?
Old 09-05-2016, 04:34 AM
TexasGuy001
The ring and pinion and LSD I have came from a low mileage 5.0 Explorer. I've never heard of that outfit. I'll check them out.
Old 09-05-2016, 06:36 AM
My4Fordtrucks
Two places. 1) Reider Racing & 2) Randy's Ring and Pinion
Old 09-09-2016, 02:12 AM
TexasGuy001
Other than one of these complete kits like Motive Gear offers which is part number R8.8RMKT and the appropriate fluid, is there anything else that will be needed? Someone please chime in, if this kit is incorrect for this application.
Old 09-09-2016, 07:42 AM
Scndsin's Avatar
Scndsin
Scndsin is online now
Clutch pack, new cross-pin?
Old 09-09-2016, 09:29 AM
Briansshop's Avatar
Briansshop
Briansshop is offline
That should do it for parts/supplies. Are you good on the tools,skills for the install? A little more involved than just bolting in. Maybe you are,just figured I'd ask so if you aren't you'll know what you're getting onto.
Old 09-09-2016, 01:14 PM
Freightrain's Avatar
Freightrain
Freightrain is offline
Since it is OEM stuff, if you kept the shims from the original install, you can at least get a good start in your housing. Not that it will be perfect but get you closer then nothing. At least that is what I've seen with most Ford stuff.
Old 09-09-2016, 02:49 PM
justcruzin125's Avatar
justcruzin125
justcruzin125 is offline
Dont bother geting a trac lok. You have the diff out already, mind as well get a tru trac
Old 10-02-2016, 01:30 AM
TexasGuy001
I've had traction lock units in several vehicles and have always been happy with them, besides I already have the unit.
Old 10-02-2016, 01:32 AM
TexasGuy001
I've read a few comments online about the shims in the Motive Gear kit not being as good as the ones from Ford. Are these from Ford Racing M-4210-A the same as the actual Ford ones or are they the same thing that comes from Motive Gear?
https://www.summitracing.com/parts/f...view/make/ford
Old 10-06-2016, 01:33 AM
TexasGuy001
Does the cross pin need to be replaced?
Old 10-07-2016, 05:34 PM
Ddaybc's Avatar
Ddaybc
Ddaybc is offline
I've got the trac lok in my 94 and I like it a lot. Having said that I will replace it with a tru trac if/when I rebuild my rear diff. There's nothing wrong with the trac lok but when I redo something I like to upgrade it if possible and money permits.
Old 10-07-2016, 08:44 PM
garthneddy's Avatar
garthneddy
garthneddy is offline
Don't forget that you can always play with the limited slip clutches to achieve a stronger engagement if your not happy with the factory performance.
Old 10-07-2016, 09:27 PM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
Personally I find there's no sweet spot in how tight a clutch-type limited slip is set up. The almost completely worn out limited slip in my '97 is still tight enough that it screws up handling in snow slightly, while being completely useless for improving traction. As far as I'm concerned an open diff is an upgrade from a clutch-type limited slip. But putting a TrueTrac in is on the project list, just not very high on the budgetary priority list.
Quick Reply: 8.8 Gear Swap & Install Kit
