I have an 03 excursions with 6.0. I downloaded the sct livewire ts and the problem started. Through truck has no power the thief light flashes codes for cam and crank sensor and on when it acts up the glow plug light comes on. On the on the ts monitor it says no key in the ignition. Any body can help
Give the people at SCT a call this weeks and ask what they think the issue is.
You might have to go with a custom tune if they can't get it to behave.
Myself I like Matt at Gearhead,
Only have links.
for SCT try https://www.sctflash.com
They should have a contact page that may have a #.
Then for Gearhead there is a link in my signature below.
So i have found out the shift on fly wont work for the 03 and some 04. Now a new problem
Today it had about 1/8 a tank of fuel and acted like it was running out. so wife stopped and fueled up. Went to start and sct screen says no communication with key. WTF this has been the worst chip ever. Any one else run into this problem with the sct livewire. Thinking edge would have been better
Yes,I have, you got to let them look at it. Make the call,they will take care of it. Make sure you do the updates first. You will love the Livewire,I have 2.
Grr,
Do the newer units up easier than the 3015 do when it not been done in some time?
The last time I had to pull the USB connector instead of ejecting it or it would not
do what it supposed to do.
I get to have fun with mine tonight I got new tune files from Gearhead today
and I should do the device firmware updats too while I am at it.
