Losing power on long hills
Apologies to the forum if this has been drug through the weeds before but it's new to me and yes, I researched the threads.
Losing power on long hills (and a few short, but steep ones).
As long as I stay less than 1/2 throttle I can make it up the hill but, if being chased by traffic and I go WOT, the motor will do okay for a second or two then start to lose power, shuddering like a tire is out of balance.
I can get out of the throttle and the motor recovers - until the next hill.
It does fine on level roads although if I need to pass a car and floor it, the turbo spools up and I accelerate only for about 4 seconds then it loses power again.
I've been through two fuel pumps in the past three years and several filters. When the first pump was replaced I looked at the bottom of the pre-pump filter and noticed a lot of black specks/chips/crud in the bottom of the filter can.
-- 218K miles
-- Oil Pressure is good/full on the stick
-- Fuel pressure gauge jumps erratically between 50 & 70 PSI.
-- Plastic fuel tank (at first I thought I might have a delamination problem)
Going to change filters later today and see if there's a change for the better but I thought I'd bounce this off the group in case you had any troubleshooting ideas.
Thanks in advance.
Greetings from Spicewood, TX!
-- 218K miles
Thanks in advance.
I have seen that picture before and/but it does not show the correct placement for the IPR on our trucks, is that a pic from a T444E? The IPR sticks straight out the back of the HPOP on the right side of the motor when standing in front of it looking at it. It is tucked down low below some wires and fuel lines. I will look to see if I have a better shot.
Maybe a clogged intake, or just a plain 'ol Hutch is needed. Can't yet rule out injector O-rings or a bad ICP sensor, though.
OBDII tools link in my signature is worth a click, and a data log will likely tell us all what's going on.
The IPR has probably been found already, but I'll share this shot of the valley "in-the-raw" - true truck ****:
Rich, your picture could be the centerfold for a diesel magazine!
So if the fuel pressure is jumping around, that is one problem, as has been mentioned-some type of restriction in the fuel line/filter/screen, etc. That would cause pumps to go bad prematurely, though. Also, if the fuel intake line to the pump is still stock, air infiltration is a good possibility if the pump is pulling air past those o-rings in the fittings.
But there is no guarantee that that is the cause of loss of power. As others have mentioned, IPR, ICP sensor, injector problems etc could be the cause. If the engine has been starving for fuel, the injector tips could have been damaged by air entrained in the fuel. It acts like sand paper. Poor atomizing because the holes are too large. Damage to the pintle perhaps?
