Steering column scrounging. Which are the same?
09-02-2016, 08:37 AM
I need one the same as my '66 has, with no column-mounted shifter. Are any later years the same? I need only the tube and shaft.
Thanks,
Eric
09-02-2016, 02:16 PM
Quote:
Originally Posted by
6t6merc
I need one the same as my '66 F100 has, with no column-mounted shifter. Are any later years the same? I need only the tube and shaft.
2WD or 4WD? If 2WD, with or without P/S?
09-02-2016, 02:36 PM
Good questions, ND! It's a 2wd without ps.
09-02-2016, 02:55 PM
6t6merc
Good questions, ND! It's a 2wd without P/S
I only need the tube and shaft.
C5TZ-3524-H .. Steering Shaft & Flange - 35 5/8" long - Use with manual steering / Flange has (1) 1/2" slot & (1) 3/4" slot / Obsolete
1965/68 F100/250 2WD / 1967/68 F350.
C5TZ-3514-J .. Steering Column Tube / Obsolete
1965/66 F100/250 2WD with 4 speed M/T
No Ford dealer or obsolete parts vendor has either one.
09-02-2016, 07:17 PM
Well that certainly narrows it down. Thanks ND.
09-06-2016, 04:24 PM
i might have one laying around. i cut down a 67 tube. i don't know if i kept the old one or not. not even sure what it originally came out of, but i'll take some pics and post them.
09-07-2016, 03:44 AM
I would think that you might find just the cuff for your existing column. ND might have column sizes and swap ability. Look at the F350 and larger for donors.
John
rexblue
25
07-03-2021 07:21 AM
hello113
05-05-2019 03:10 PM
docno
01-27-2014 05:42 PM
BrotherMabe
13
02-03-2013 02:40 PM
cordele79
01-22-2013 03:11 PM
