Another Crown Vic Suspension Swap 66 F100 aka "60sick" Build
Hey all I just thought Id share my build along side of all these other inspirational builds going on. Im not a crazy fabber nor do I have thousands in shop tools. Im just your average handyman some of you may cringe at my techniques and Im ok with that lol. I urge your constructive criticism and look forward to this adventure.
I picked up a 1966 ford f100 with no motor or trans out of a barn for 2000. hit it was some sand paper and dropped a 69 t-bird 429 thunderjet and c-6 into it.
I daily drove it like this on manual drums and steering until I tore the studs clean through the hub assembly ...all 5. scary!
So here it is 08 crown vic p71 font subframe swap.. for some maybe not the cheapest and most effective way but for me to get lowered , pwr steering, and brakes I can work with ford ..I know and am comfortable with ford ..jag and whatever else truly kinda scares me.
on to the build.
this is when I was driving it as it was before the breakdown
on the road!
heres when I added some white wall inserts
68 t-bird 429 thunderjet on c6 trans
day 1 start removing tires and brakes since the passenger side removed itself already all by itself lol
note my hub assembly holes for the studs
you can see how much bigger they are on the pass side Im lucky I was just cruising on my street when the tire folded under.
so first on the list of to do's..drain the fluids and tackle the front clip.
08 cv p71 subframe
so it went really well!. I spent 2 weeks just hitting every bolt with liquid wrench before actually starting the work
progress..
cab will need to come off to do the floors and mounts but thats later
so next welded on the temp cross member and ready for a motor pull
so I called my buddy LOL
too easy really again I dont have all the tools but I do have amazing friends and family!
well with the motor out the next step is to mark out the old axles centerlines on the frame rails and pull the old ibeams out
just a progress pic very happy!
cross member shot
another cv subframe shot before tare down
so I got the box off too , I want to have the floors fixed up on that and also deal with the rear axle flip or swap or just hanger kit well see ...still researching on this and pondering..
this is the ed ritchie cv to 66 ford mounting kit complete and ready to rock..
this is the cv to ford 429 motor mounts also from ed ready to rock
here are the trailing arm bushings..they have been cut open and rotated for proper alignment adjustablitly.
so thats where we are at folks... this weekend pulling the ibeams and the cross member..stay tuned!
Koomz
on to the build.
on the road!
08 cv p71 subframe
progress..
cross member shot
Koomz
Looks like a great start so far. I'm loving the 65 grille on the 66. Does the ED kit come with everything to make it a direct swap no fab work yourself? Do they have 351 Cleveland motor mounts for the cv subframe? I'll be watching. Just picked up a 66 myself and it came with an 07 cv in the bed deciding if I want to use that or a jag IFS
LOKKS like a great start so far. I'm loving the 65 grille on the 66. Does the ED kit come with everything to make it a direct swap no fab work yourself? Do they have 351 Cleveland motor mounts for the cv subframe? I'll be watching. Just picked up a 66 myself and it came with an 07 cv in the bed deciding if I want to use that or a jag IFS
I'll have to check into there bolt in kits. I looked into another company that does the same thing just have to do the assembling and welding as well. I want to use it but I've always been kind of against the CV swaps due to the wide width and slim selection on wheels and offsets. I guess time will tell if the 66 sticks around long enough. Keep up the progress.
To the op...im subscribed to this thread
cheers ryder do the research see what suits you cause its really a matter of to each their own ..this is what im after plus im just doing the 8.8 rear to rock a deep dish steelie or stang rims..this one has a cv rear but non the less i love the skinnies up front so again its what your style is ...build it!
i did my motor swap like yours but I sub framed it with the ltd front frame,so I had a 460/429 heads plus disk brakes coil springs,i just purchased a 09 crown vic was going to use the frame,but after I drove it ,the 09 is real fast on the high end side,nice project keep us posted,
on to the build.
on the road!
08 cv p71 subframe
progress..
cross member shot
Koomz
on to the build.
on the road!
08 cv p71 subframe
progress..
cross member shot
Koomz
Sorry sounded to me like you had a jackass comment specially with Jesus tacked on the end in my world that English sentence is sarcastic so if your gonna ask a question then ask it!
