Wastegate Adjustment - 38R Stage 2 Sticks?
For my 2003 Excursion, with Stage 2 injectors - 175/80's and 38R, should I tighten the wastegate rod all the way down, effectively disabling it, or should I turn it down only 7-8 turns? Further, if I do run it turned all the way down, should I plug back in the red hose that goes to the wastegate? Right now it is unplugged and capped.
I capped my red line with the factory-set WG - nothing useful came of that. I read the "destructions" after the install, and realized I should have read them first. WG adjustment is an important section on that sheet of paper. I ended up doing it in the truck... very carefully with an uber-Mythbuster's magnet in close proximity - to catch the E-clip when it flies off.
I applied air to the actuator to test the results of my adjustment, and my technique was to tighten it until locked closed - then back it off so it can still work. I use the red line right now, so as not to exceed 35 PSI... old valve springs. The next motor has 910 springs, and I'll learn what happens when I cap the red line.
simpsomatt
17
01-11-2017 03:01 PM
Meydawg51
27
04-06-2015 03:41 PM
