Metal glove box
You can buy plastic glove boxes from jeffs bronco graveyard. If you don't weld use rivets with metal like the link shows. Another thing is if you have air conditioning it makes it very difficult to remove/install the glovebox from behind the dash board. With cardboard or plastic it allows some flexibility to install/remove through the glovebox door hole.
I made one out of Aluminum for my Galaxie.
Took the old cardboard one and used it as a template. Wasn't that hard.
I spot welded mine, but I'm sure you could use rivets.
Only regret is I didn't use the bead Roller on the back section and write something like "Ford" or "Galaxie" on it.
Wish I had pictures to show but I'm offshore and cell signal is weak.
JBG, cheap, quick and easy.
Cardboard $16 1973-1979 Ford Bronco and F Series Truck Glove Box, Replacement-Broncograveyard.com
Plastic $27 73-79 Bronco & F-Series Glove Box, Ultimate Plastic Liner-Broncograveyard.com
Or essentially you're buying a $12 template if you'd prefer metal anyway!
When I get to restoring my interior I'm going to give this metal box a whirl... If I get it done I can post measurements and drawings for future reference. (Note: it could be a while before I get to it tho so don't wait on me lol)
