Looking at a 2002
Old Aug 26, 2016 | 10:08 PM
wtroger's Avatar
wtroger
Looking at a 2002
Looking at a 2002 Ranger xlt extended cab 2wd 3.0 v6 with 5 speed AT trans. Step side. Any issues to look out for it only has 57,000 miles
Old Aug 27, 2016 | 03:55 PM
cracked block's Avatar
cracked block
Had one, but I think it was losing a cam bearing when I traded it. Might be something to look into before you buy. Good luck and let us know how you make out.
Old Aug 27, 2016 | 04:30 PM
spooktn's Avatar
spooktn
I know that on my 99 and some others older models had a issue with the camshaft schyronizer not getting oiled well... not sure if it was fixed by 2002,,,, but the part is not that high and fairly easy to install if you are a mechanical person,,,, the bushing would not get oiled and cause major damage if it failed while driving,,, it spins the oil pump,,, something for you to think about,,,if it is bad it sounds like a belt squeak or a chirp
Old Aug 27, 2016 | 05:04 PM
wtroger's Avatar
wtroger
Bought it dealer came down to where I though it should be. Clean garage kept. runs good drives good. Time will tell.
46fordtruck
15
Sep 6, 2016 02:05 PM
littlefoot_munchie
Nov 17, 2010 02:51 PM
86rangerman
Aug 18, 2008 06:38 AM
dybeepvw
Aug 5, 2007 02:32 PM
1524
13
May 19, 2005 08:38 PM
