How To Remove Front Driver Side Shock on E350 in 15 minutes
I found a way to remove the dreaded front driver side shock on the E350 that takes about 15 minutes.
I searched online "how to remove front driver side shock from Ford E350" and discovered most E series vans have a small cut out hole located above the front driver side shock for running cable. I pulled the grommet off the hole and was able to get a socket over the nut!
I cannot believe that I missed this grommet so many times. I have 2 of these vans and I ran electrical wiring through smaller holes. This hole give amazing access.
I believe I can have the shock removed and replaced in 30 minutes or less.
Here is the Youtube video that I posted today.
Last night I got so excited about finding this hole about the size of a silver dollar that I ordered Bilstein front and rear shocks on Amazon and they arrived tonight. I sprayed the hardware on the front shocks with WD40 last night and the nuts turn easy. I will get all the tools staged, jack up the front of van and rest it on jack stands. Plan on removing both wheels to make the installation easier. Once I have all the tools in place, I will time the removal and install.
I was ready to pay a shop 2 hours labor for the install of the front shocks. I searched an entire year on how to do this repair. I found 1 youtube video and and 1 short forum posting on the cable routing hole. BINGO!
I replaced both front shocks this afternoon. I removed both wheels as I wanted as much space as possible while working under the van. I am super cautious and used 2 jacks stands and placed the tire under the van for extra protection.
I had the driver side shock pulled out in about 15 minutes. I wonder if Ford made the hole in this location to make getting the shock out easier? An engineer may have slipped this in without telling upper management. The hole is way too big for the small cable that is routed through the hole.
I wrestled with the shock trying to compress it for 45 minutes without success.
I told my son to find the roll of duct tape that we used on our last back packing trip to make insulated cozies for our cook pots.
The first using a single piece of tape broke during the install. On the second try, my 15 year old son stuck 2 pieces of tape together for strength. Noting like working with kids for help!
I compressed the shock and and placed the bottom end of the shock on the center of a double piece of duct tape. My son quickly stuck the tape on each side of the shock tube. Next, he wrapped the tape to secure it tightly to the shock. It held as good as a zip tie and was easier to secure the shock. Too bad I forgot the washer under the rubber bushing! Our 3rd try was a success.
My son video taped the entire process. The second passenger side shock was removed and replaced in 30 minutes.
The driver side shock took me 2 hours to replace because I had no idea how to keep the shock depressed.
Between prep time and clean it, the process took nearly 4 hours. If I do this again, it will take me 2 hours total for the front shocks.
Duct tape is amazing. I have used zip ties in the past as many shocks come packaged zip tied. This was not the case with the Bilsteins.
I climbed under my van and looked at the rear shocks. There is less room to get wrenches around the nuts than the front shocks. However, I don't have to remove the wheels.
I estimate an hour per side.
We will edit and post the video some time this week.
It should be the same on all vans (150, 250,..) they all have the same body, different chassis.
I do not remember being too difficult to remove the shock absorber, but that hole will help for sure. Thanks for sharing
I drove over the Altamont pass on I580 West in California today and it's the worst freeway section that I have ever drove on in my entire life. My van usually bounces and nearly becomes airborne. I did my first test drive with the Bilstein shocks in the front and this time I was able to drive without fearing death. It's still a bad road.
My tires are worn severely from previous poor alignment and possibly from bad shocks. I cannot say with a degree of confidence that the van drives noticeably different on regular pavement because the tires are so uneven.
The tires probably have only 20k on them. I plan on putting another 5-10k before I buy either the Cooper AT or Michelin ATX.
I replaced the ball joints in February. Installed a camber kit because the camber was off. The tie rods feel a little loose so I may replace the tie rods before I drop $800 on tires. Little by little I am chipping away at the van and making it drive smooth.
Shocks do indeed affect tire wear! A bad shock will cause the tire to "jump" up and down and will wash out tire tread badly.
Tie rods for sure also affect tire wear, but I don't know what a good Blow Job has to do with rubber wear SCNR
