Wheels for 1948 F1 with disc brake
Old 08-24-2016, 02:51 PM
kens65fb's Avatar
kens65fb
kens65fb is offline
I am planning to update my F1, with the speedway motors front disc brake kit, and an explorer rear end.
Both axles will now have the 5 X 4 1/2 bolt pattern.
I would like to run plain steel wheels, any suggestions on where I can buy an economical set of wheels.?
I was thinking 15 X 7 wheels would fit nicely, and look good, but I am not sure of backspace.
Anyone done this swap ???
Old 08-27-2016, 04:58 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Too bad that you don't live closer. I have a pair of 2001 Ford Explorer wheels & tires that I got from a U-Pull-It yard in Flat Rock that I no longer need. There are some U-Pull-It yards near you. https://www.google.com/#q=u-pull-it+...s+pennsylvania
I have the same setup with the Speedway front discs and an 8.8" Explorer Sport Trac rear axle. I had Wheelsmith make me a set of steel, '34 Ford-style artillery wheels.
Old 08-27-2016, 05:07 PM
kens65fb's Avatar
kens65fb
kens65fb is offline
NICE !!!
Looks like added a automatic trans to your flathead, is that a C-4?
I also plan to put in an automatic, what adapter did you use for the swap.
Ken
Old 08-27-2016, 05:20 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
No, it is a Ford 4R70W so I don't have to mess with mechanical throttle linkage adjustment.
dlb.motorman
19
02-25-2020 02:22 PM
anthony myrick
Ford Truck Parts for Sale
16
02-21-2017 07:50 AM
truckdog62563
10-19-2012 03:33 AM
hotwheel_2000
09-19-2012 11:29 PM
Jolly Roger Joe
29
07-31-2011 11:20 AM
Quick Reply: Wheels for 1948 F1 with disc brake
