F-150 for towing a 5th wheel
Hey guy's, I just purchased a 2013 F-150 Lariat Crew cab with a 6.5' box, 4X4 and the 3.5 eco-boost, I would like to get opinions if you think I could safely pull my 5th wheel RV with it.
My RV is:
2000 Sportsmen 2653P: UVW= 6,740 lbs., Dry Hitch weight= 1,480 lbs.
The truck has the Max Tow package, but NOT the HD payload package (I had 14 dealers looking for one of these for the last 7 months with no luck). My previous truck was not safe/dependable to travel with anymore so I bought the 2013.
I do see quite a few F-150's pulling 5er's, but want to hear from all of you on this forum.
Thanks
My RV is:
Thanks
Here is my confusion: I've read that the 2013 has not changed in capacities (pay load, max tow, etc.) from the 2011-2012 F-150's, but the 2013 specs brochure refers to trucks having the heavy duty payload package (which I and 95% of others do not have).
The 2012 specs:
To me, this looks like having the max tow package, I can have up to a 1,840 pin weight. That's pretty darn heavy if you ask me. Am I reading this correctly?
The 2012 specs:
I don't spend much time looking at tables, but I read that as you total payload capacity, that is everything that goes into or on the truck, not just the pin weight, right? Like the folks in the cab, maybe the folks' dog or kids, the hitch, whatever else is in the bed. Our fiver has a 1,600 pin weight. Put my wife and I in the cab and even if we left the bed empty, we would be over the payload in the truck in this example.
In the "for what it is worth category' I have actually stopped to talk to folks pulling fivers with 1/2 tons, not just eco boosts and I haven't heard complaints about power, just some comments that it does not handle the weight as well as a heavier model. Nothing dreadful, but a feeling the fiver had more effect on the truck. And, none of this is mountain towing. We uns here in the Volunteer leave the high stuff to our friends west of the Mississippi.
Steve
Steve
That 1840 is how much weight you can carry in the truck on top of its curb weight.
So if the truck weighs 6000#, then you load the truck with people, stuff, and hook the trailer to it, the front and rear axle weights added together should be under 7840#.
But there's also front and rear axle weight limits and the rear axle is where you are going to reach the limit fast. A white and yellow sticker in your door jam should tell you the axle gross weights.
If the pin weight of the 5th wheel is 1480 then you and all your stuff in the truck needs to weigh less than 360# or you'll exceed your payload capacity and most of that will be on the rear axle.
Steve
CAT scales at truck stops measure weight on front and rear axle of truck and weight of the trailer, so you drive onto three separate pads. Very easy to do. Weigh your truck empty first set up as it would be when you are towing, i.e. full of fuel, passengers (or nearly so), etc. That way you know how much weigh your fiver adds to your truck. Truck with fiver hitched minus truck without fiver hitched gives you pin weight.
Steve
Steve
Cat scales are a good deal...$10 per weigh ticket is nice peace of mind. Weight can really creep up on you. Our 3/4 ton is rated for 3200 payload. I weighed the truck "empty" and found out my few wood blocks (for jacking), 5 gallon of spare fuel, aftermarket running boards, me in the truck and my fiver hitch added a lot more weight than I thought. All that only left me with 2300 lbs of payload. Add my family and fiver and we are just under the limit. Fiver only weighs 10,300 (well under my tow rating). I'd have to put my truck on a diet to tow a bigger camper.
I had watched this video, but my question: The first weigh-in, weighed the truck, not individual (front/rear) axles. Should he have had both axles weighed in separately and then do the second weigh-in like he did?
The weigh-in starts at ~2:00:
The way it was done, can you tell what the pin weight is? (I realize it's a TT), but the rear axle should still have more weight on it compared to empty.
Also, what does it cost to get weighed?
Thanks
Thanks
