Lube Fitting Locations - 2002 F250 Super Duty - Ford Truck Enthusiasts Forums
Oil & Lubrication
Old 08-23-2016, 12:23 PM
D.Yaros's Avatar
D.Yaros D.Yaros is offline
D.Yaros is starting off with a positive reputation.
Am in search of a lube chart/diagram for a 2002 F250 Super Duty XLT V10 long bed.
While I did find 4 fittings on the front suspension, I suspect I may have missed some in other locations. Tried google to find a chart, but no luck.
Any pointers? Appreciate it!
Old 08-30-2016, 11:13 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
If my memory is right I only had 4 grease fittings on my 04' when it was new, only on the tie rods for the steering. I have since added greaseable ball joints and greaseable sway bar end links so my number of grease fittings now has increased quite a bit.
Old 08-31-2016, 06:04 PM
D.Yaros's Avatar
I appreciate your sharing that with me. Guess I got them all when I did the lube.
Old 11-24-2016, 02:24 AM
Huskerwrench's Avatar
Huskerwrench Huskerwrench is offline
Huskerwrench is starting off with a positive reputation.
Quote:
The ball joints upper and lower, provided they are no longer original will have zerks as will the steering. I'd check ujoints too because if they've been replaced they may have a zerk in the cross, or end cap. The ujoints on both sides to the front axle too. Also, it might be worth greasing the rear driveline, however there isn't a zerk. Do a quick search here or YouTube and you can learn how that is done. Lastly I believe there is a zerk on the front driveline for the slip there.
Wipe em off and fill em up. It's time well spent!
Gear lube tests 03wr250f Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 02-12-2018 02:51 AM
New to Towing Question 191124x7 Fifth Wheel & Gooseneck RV Towing 11 11-19-2016 02:48 PM
Rebuilding Pulleys - Parts? Tylus 1987 - 1996 F150 & Larger F-Series Trucks 3 11-05-2016 09:13 PM
Lube Points - 2002 D.Yaros 1999 to 2016 Super Duty 0 08-22-2016 05:08 PM
door and cab speaker wire chart for 96 CC f100today 1987 - 1996 F150 & Larger F-Series Trucks 0 07-19-2016 10:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
