Balancer not flush to Crank Snout
Does this look correct?
390 FE with Eagle 4.250 Stroker Crank
Spacer Sleeve is on all the way. Checked oil slinger before installing oil pan and it was tightly squeezed between time gear and spacer.
Harmonic Balancer does not come close to being flush with crank snout.
Thoughts:
-No it shouldn't be flush.
-It needs to be tightened with the bolt, if the bolt bottomed out it wouldn't really be holding it on.
-Aftermarket crankshafts are a lil wonky, especially with the keyway, make sure the keyway isn't binding the whole works. This is important to check on the crank spacer as well as the balancer. A belt sander and gentle adjustments to the key are required for perfect fit.
Good luck.
Good luck.
olderford76
09-14-2015 07:38 AM
boxer.fan
08-19-2009 05:50 PM
lifted77f250
15
04-10-2006 09:32 PM
Rat wagon
01-24-2003 07:43 PM
Crazy_John69
03-23-2002 02:23 PM
