wiring harness replacement
are there suggestions on manufactures for replacement harnesses. my 1966 f100 has an 1980ish 302- but no new electronics. Existing wiring cracked somewhere in the original under dash loom and shuts down the entire system-- shake it and it works. Its time for replacement. American autowire sounds good but matches GM colors. is this going to be a problem? any help appreciated
Scott
Scott
Purchased individual harnesses by American Auto Wire thru Mr. Mustang, they no longer carry them; very pleased, wire color codes, and connectors were identical to the original. Unplug original and plug in new.
Posting link to Mac's just as an example, what got my attn., Mac's list individual harnesses; I would assume if by the Ford P/N; i.e., C5TZ-14290, headlight harness, it should have the same wire codes and connectors as original. If considering suggest contact to confirm who the manufacturer is, whether the harness has the same connectors, and wire color code as original.
Search Results For: Wire Harness For All Years And Models Parts & Accessories
What harnesses are you looking for?
Thanks all for your suggestions.
The Ron Francis seems similar to the Painless unit. it appears to require that each wire needs to have a connector crimped or soldered on to make a connection. and runs about $400-$470. The American auto wire unit seems to have all the connectors installed and its a "plug-on" and runs about $680 Why do you need the crimp tool that was recommended in other articles?
I'm an old guy non mechanic - with bifocals and that is irritating trying to focus on the pin then away to the wire to crimp then back to close work. So i'm trying to justify the Americanautowire extra cost
Dave and Steve-how long did the job take you with Autowire system
Thunderkiss- do you have a time for the complete job?
Since all wires are original and been modified many times, I plan to do a complete job so I know what I have.
Scott
Scott
The dash harness was not available when I replaced the harnesses. I only replaced the 'alternator', 'headlight', and 'taillight' harness. Except for the alternator harness, which I ended up removing, with the other 2 it was a matter of unplug the old and plug in the new. The taillight harness I purchased could be use for the short, or long bed, so rather than cut and splice, I ended wrapping the excess and using plastic ties to set aside; otherwise, don't believe I spent more than a couple hours at the most?
The dash harness was another matter, I removed it and made necessary repairs. May want to consider adding a dab of dielectric grease to the connectors, and clean any grounding points while installing the replacements. In event decide to purchase the taillight harness may want to consider cutting 2"-3" piece of hose, or something similar to protect the wiring when running thru brackets, cavities, etc.
Here are some general before (Holy rat's nest!) and afters, and a pic of the kit before install:
Scott
Scott
Not sure why but if you order the American Autowire kit from Summit it is cheaper than ordering directly from the manufacturer.
Yep, AutoMeter for oil, fuel, water and volts. Quality and good looks.
tanks for the pics thunder looks like original wiring in your truck was done by my PO
looks like you bypassed the 5 volt cvr on the dash and upgraded the lights and perhaps gauges on the dash wiring I was wondering what happens there
thanks Pruitt66 I hadn't noticed that
fatheroftwo
01-16-2016 12:22 PM
F250GH
10-05-2008 10:50 PM
