Belt tensioner
I'm running Gates 38119 in both our trucks. They have a longer arm, which I find works better. Of course, the best option is the SD BT-50 swap - http://www.thedieselstop.com/faq/949...les/982314.pdf .
Supposed to be more durable and it's just a cool mod to do.
Kevin
Because both pulleys pivot, the belt is kept in a straight line better. With the single-pulley tensioner, as the spring wears, it eventually causes the pulley to get out of line when it unwinds and tensions the belt. You can actually see it "twist" at a slight angle as you let off the spring load with the wrench. With two pulleys acting in opposite directions of force at the same time, the spring doesn't allow that to happen over time. I just didn't do the mod on mine because in both cases, I needed the truck up and running quickly and no one had the BT-50 available locally.
That makes sense and will likely go that route in the future. I picked up the tensioner and idler pulley so hopefully they last for a bit. I want to run it stock for a while but once the oil pan begins to leak like it is prone to do, when we pull the engine to replace it, that will be my green light to start pushing the new mods.....need it to run for a little bit to build up funds to replenish the pockets from the front end rebuild.
powerstroker100
11-22-2011 08:06 PM
dakotajeep
10-09-2007 11:05 AM
andy wick
09-28-2005 02:43 PM
