Any advice on 1969 429
Thank you
As much HP as possible? That's too open ended... I think the approach should be how much HP is possible with a $Xxxx budget.... Then search out various engine combinations that can get the engine to that level. I'd take a look at Jon Kaase's engine combos.
So no one has ever used the Edelbrock top end kit on here then
Aluminum heads also dissipate heat faster and are better for high compression engines.
First thing you need to do is to check to see what rods you have, If you have the football bolt head rods you are good to go, chances are you do. If you have the square shoulder bolt rods you need to change them out they should not be used in any kind or performance application at all. At 400 HP it is not a question of if they will fail but when they will fail. It may be at 5K miles or 80K miles but they will eventually fail.
Also what are you looking for, bottom end mid range or top end power.
Personally the 385's are all about torque and chances are you are hardly ever going to spin the motor above 5500 RPM. If it is going to regularly see above that new rods should be considered.
The stock heads are easily good for 400HP I would save the money of the Edelbrock kit and spend half as much on the top end.
You do not want to exceed 10.5:1 compression and still be able to run good quality regular fuel.
Personally I would go with the Weiand Stealth intake and a 750 CFM vacuum secondary Holley. I have run this combo in the past and had no complaints.
Cam selection is going to depend on what you want. Do you want stump pulling off idle torque, Mid range power or top end Lumpy idle or smooth factory idle. The Cam in the Edelbrock kit is rather mild.
The cost of putting together a package is going to cost less than a third of the of the $3500 Edelbrock kit.
Spend the money saved on the stock heads, they are easily good for 500hp with some exhaust porting work. have the machine shop do some porting on the exhaust side (intake is fine) up grade the springs and keepers, machine the seats (If needed depending on cam choice) , machine for positive type valve seals. And use ARP bolts through out, You will save your self over grand and end up with an engine that is better than the Edelbrock package.
I take it that you've already been to a competent machine shop and gotten a report on the health of the block, crank, etc. If not, you'll want to do that before developing your plan for max HP and torque within your budget.
Is the block in good shape and does it need to be bored and, if so, what are your overbore options based on current bore and sonic testing?
Is the crankshaft going to be reusable with modest resurfacing (less than .030" under, preferably .010 under).
Too bad you don't have a good pair pf the '69 heads. They were designed for performance whereas the later models were designed to lessen smog. For aluminum heads I don't think that the Edelbrock units are as highly regarded as those from Jojn Kassee Racing, Trick Flow, AFR and Ford Racing. Kasse even makes a Boss 429 type head which is impressive in both appearance and performance.
It may well be worth your while to spend some time on the 460 Ford. com web site.
This 2009 post presents a handy chart organized by horsepower output.
I agree with flowney and matthewq4b....do your homework after making sure the block, etc, are in good shape. My opinion, for what it's worth, is that Edelbrock is over - rated.
itsabullitt
30
09-23-2013 01:08 PM
shadow_almanza
15
11-08-2010 08:00 PM
bowtie bruiser
01-31-2008 07:01 PM
tess100
11-16-2004 09:53 AM
