Problem with my 97 F350 crewcab
I'm going to be in Rabun Gap GA, Bennettsville SC, and Sanford NC next month and I'll have my AE software and laptop with me. If you're still having problems, I'm sure I could swing through there and help you out!
Vgate BT dongle under 10 on ebay
Bluetooth Mini Vgate Scan OBD OBD2 V2 1 OBDII Auto Torque Scanner Tool ELM327 CD | eBay
then android app you buy but some free ones do well
https://www.ford-trucks.com/forums/1...the-cheap.html
then you can monitor things and get codes
Update. I ordered the Bluetooth adapter. But there is another problem. Know this just started yesterday evening. When the trans is cold you have all gears. But know when it get warmed up you lose high gear but at times you can feel and see the tach showing it trying to go into high gear. What would cause this? Would the solenoid pack in trans going bad do this? Thanks
#30
Does you adapter have any lights on it to verify that your OBDII port has power? Does your cigarette lighter work, (have power) as it is on the same fuse as the OBDII port?
Here is the steps I use with my BAFX Bluetooth adapter:
I first plug the adapter in
Then turn the truck key to on.
Open Torque Pro.
Then with my old Samsung phone, I had a pairing request on my phone where I had to enter the 1234 PIN. The blue Bluetooth adapter icon would be solid (my LG phone remembered the PIN after the first time I paired with it).
Then Torque would scan all protocols and use the J1850 to talk to the truck.
And then the car icon would stop flashing. It takes about 20 to 30 seconds to connect for me.
I have my Bluetooth turned off on my phone by default and have Torque Pro setup to turn on Bluetooth when needed.
I have had trouble in the past when my phone was paired to other things while trying to connect to the Bluetooth adapter and my truck.
Kevin
Open Torque Pro.
Kevin
