Late 99 F250 cc 4WD front brakes
08-17-2016, 07:15 PM
Drivers side caliper not releasing.
Question 1) should I be looking beyond the calipers?
2) Any affordable good quality parts recomendations?
08-17-2016, 07:51 PM
If it's not releasing it may be the caliper but more than likely it's the brake line collapsing.
08-17-2016, 08:28 PM
slide pins could be corroded
08-17-2016, 08:44 PM
Quote:
Originally Posted by
schlepprock250
Can you tell me what to look for in way of a collapsing brake line. Is this something you can observe without removing it?
08-17-2016, 08:46 PM
Definitely check the slide pins first. It's very common for them to seize in their bores, particularly the lower ones. Is the inner pad worn more on one end than the other?
08-17-2016, 08:50 PM
Pikachu
Ah, too late for that, no pad left in the inter side.
pump the brakes and then see if that side is applied / stuck. open the bleeder momentarily and see if it releases. If it does then fluid was trapped.
08-17-2016, 08:52 PM
I will check pins in the morning and buy one new rotor.
08-18-2016, 10:46 AM
Problem found
Rubber boot on piston is tore and piston is sticking on left front caliper.
Thanks for the feed back.
Tex51
06-18-2019 08:50 PM
fxef79
05-02-2019 05:44 PM
GK4x4
03-26-2008 08:11 PM
jpetit
1997 - 2003 F150
09-11-2005 11:24 AM
wheelzzs
1999 to 2016 Super Duty
10-07-2004 08:39 PM
