Sometimes my truck is dead when I
try to start it. Today, I had a friend watching as I tried to start it. He saw a spark that looked to come from tha (2) long bolts that go through the starter. I crawled underneath and found a little play in the wire to the solenoid. I tightened it an the truck started every time . However, I still saw a little bit of a spark when my friend started the truck. Is my starter going bad? Any experts with good advice? Thanks in advance.
I have started the truck two
times since my last post and 5-6 times in a row. After tightening the solenoid wire the spark grew smaller and disappeared after three starts. I have started the truck another two times. One with no spark and the other I did not have anyone to watch for it. Thoughts?
I checked and tightened the bolts this morning. The big bolts were tight but the (2) Small headed bolts that come out of the front of the starter were a little loose. I tightened one about 1 1/2 turns and the other maybe 1/2 turn. The truck started every time (approximately 10) today. Then I came home, the truck was off less than 1/2 hour and was dead when I tried to start it. On the 3rd try it turned over and started. Does this sound like the starter internals are shot. Is it time for a new starter? Thanks again.
Thanks Nick99. The guy that I know at the parts store
was the person that said what you said. But, he told me that my starter and solenoid come as a unit. He ordered both units (two different starters because a 2001 7.3 showed three options on his computer) and I am going to take mine off in the morning so we can match it up. Besides disconnecting the batteries anything else I need to be aware of? Thanks again.
