96 7.3 5 speed manual question??
OK guys my flywheel inspection cover on my 96 7.3 5 speed manual transmission finally gave up the ghost and broke.
My question is just what does Ford call this thing? I've looked all over ebay and the internet and can't find one. I've always called them flywheel inspection cover or inspection plate.
Does anyone know where I can get one, about how much do they cost and doe they make a heavy duty one not prone to breaking?
Can't be that expensive to ship. If you get an old one, it has a flange that faces forward, and when it's installed, it's so close to the engine oil pan that it can cut through the pan over time. New improved OEM version doesn't have the flange. If you get an old one, you can trim/grind it off.
But I gotta wonder, how did you break yours? Off-roading?
D'OH, I just remembered, there's a TSB for the issue I described above. Went over to "the stop", and sure 'nuff it's in the FAQ/TSB section - http://www.thedieselstop.com/faq/949...les/951412.pdf . Part number is in the right-hand column. Seems to go by "clutch dust cover plate" or "engine rear plate" (shrug). Looks like Sunrise Ford Parts (they're a sponsor of at least one of the truck forums has it, if you're ready for some sticker shock.
