Is your door cracked? - Ford Truck Enthusiasts Forums
Old 08-19-2003, 09:28 PM
Zigman
Zigman is offline
Zigman is starting off with a positive reputation.
Angry Is your door cracked?
Hi all,
I have a 1997 f 150
And on the drivers door, on the lower right side(from the outside) of the window, where the 2 peices of rubber trim on the window meet, there is a small crack in the metal. I heard it was some kind of stamping issue on the '97's.
Just wondered if anyone else has it, and if Ford will fix it?
Thanks,
Brian
Old 08-19-2003, 10:19 PM
JeremyH
JeremyH is offline
JeremyH is gaining momentum as a positive member of FTE.JeremyH is gaining momentum as a positive member of FTE.
Hummmm.....my sister's truck isnt like that....hell take it to the dealer to see if they will fix it. There might even be a recall on it. Look here: www.alldata.com
Yep..... http://www.alldata.com/TSB/20/972016BX.html #29...of course that is only a bulletin and the dealer is not required to fix them.
Old 08-20-2003, 07:20 AM
Shernius
Shernius is offline
Shernius is starting off with a positive reputation.
Smile Is your door cracked?
Iíve heard a lot of people having this problem but my 99 doesnít have that problem or at least not yet. I didnít pay attention if there were certain years involved. I would do the old search thing.
Old 08-20-2003, 09:03 AM
AegisSailor's Avatar
AegisSailor
AegisSailor is offline
AegisSailor is starting off with a positive reputation.
Common problem on the 97's also check TSB 01-18-2
Old 08-20-2003, 11:33 AM
jmr1653
jmr1653 is offline
jmr1653 is starting off with a positive reputation.
Wow, I've never heard of this. I have a 97 and my brother has a 97 and neither of us have the problem.
Old 08-20-2003, 01:12 PM
Pammyj1968
Pammyj1968 is offline
Pammyj1968 is starting off with a positive reputation.
When I bought my 97, 2 yrs ago, I noticed a crack. Actually a chip of paint missing at that location. I had Ford fix it for me, but I was told it happens to all of the newer body styles. Caused by slamming the door and/or the window moving up and down. Also, it will eventually happen on the passenger side. There is a fix offered by Ford but not permenant. It is a bar that gets welded at the weak point, causing the weak point to be moved further up the bar by the window. The new trucks are being sold with this fix. I had the door skin replaced and painted. Also, I don't allow anyone to slam the doors.
Old 08-26-2003, 08:15 PM
pro3qtr
pro3qtr is offline
pro3qtr is starting off with a positive reputation.
Yes, the fix is worse than the Crack!!!
Old 01-08-2004, 01:27 AM
speedaholic
speedaholic is offline
speedaholic is starting off with a positive reputation.
mines cracked
just bought a 2000 150 4x and it has a crack on the drivers side door, will the ford dealers fix it or do i have to pay for this fix? thanks.
Old 01-08-2004, 01:31 AM
pro3qtr
pro3qtr is offline
If u still have your 3/36k mile warenty, yes the dealer will fix it !
I am planing on buying new doors, then fix my cracks.
Deciding whether to keep the truck or sell it.
Old 01-08-2004, 02:31 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
No cracks here Knock on wood., it sill has all of it's spark plugs in it too, it must be a keeper!!
Old 01-08-2004, 01:08 PM
Jimmy Dean's Avatar
Jimmy Dean
Jimmy Dean is offline
Jimmy Dean has a very good reputation on FTE.Jimmy Dean has a very good reputation on FTE.Jimmy Dean has a very good reputation on FTE.Jimmy Dean has a very good reputation on FTE.
Actually, the crack is caused by trapped air inside the cab when the doors are closed, the sudden pressurization will over time crack the door skin. 97s and 98s have this problem, they got rid of it by installing relief vents in the back of the cab on the 99-up models. Apparantly the Fords are to air tight at least it dont leak.
Old 01-08-2004, 01:15 PM
pro3qtr
pro3qtr is offline
U have proof Dean??? Over time?? Try less then 20K miles.
My 98 has said vents and I have seen cracks on 99 trucks.
Old 01-08-2004, 01:26 PM
Jimmy Dean's Avatar
Jimmy Dean
Hmm..perhaps it still happens, but not to the degree it used to, from what I seen it was one in say 3 or 4 97/8 trucks got the cracks.....
Old 01-08-2004, 02:41 PM
freak98's Avatar
freak98
freak98 is offline
freak98 is starting off with a positive reputation.
I,ve seen it on 97,98,98,00.The fix is that they put on a new door skin,and the one's I've seen you can tell they've been painted.Mine is cracked(98 F-150)but it's small and it hasen't got bigger,so I'm leaving it alone.
Old 01-08-2004, 02:46 PM
odie15
odie15 is offline
odie15 is starting off with a positive reputation.
My 99 cracked on both doors. Lucky I found them while under warranty. Dealer installed stiffiners and repaired skins. Friend of mine has a 98. Both of his doors are cracked.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
