I6 or v8
Old Aug 12, 2016 | 12:42 AM
1966f100ranger's Avatar
1966f100ranger
I6 or v8
Im in a real pickle here guys. Like I have said in a few of my posts, my 66 f100 is an all original barn find.. I absolutly love the truck. The only problem that arises is the motor. it runs great, but I need to put a new exaust on it, and would like to add a few upgrades.. ie split headers and add a 4 barrel carb. Which all costs money, but that will leave me with the original motor with a few bolt on parts. Heres where the question arises... I have a 68 as well thats a total pile. It has been eaten by salt and rust, so no box and the cab is barely on . thankyou WI. anyhow, it has a 390 with only about 70k miles and a Torg borner 4 speed ( same as my 66)... what should I do? No replacement for displacement, or a few bolt on parts to my original 240..... Or... just not touch the motor at all... let me know what you guys think.
Old Aug 12, 2016 | 04:18 AM
jowilker's Avatar
jowilker
For me, I'd go with the FE with a C6. Damn a full grown Ford truck that can't shift its own gears. A lot of guys like the 6 banger but I don't care for them.
Sounds like you have a motor and no truck, and a truck with no motor. Make one and sell the other.
John
Old Aug 12, 2016 | 12:42 PM
ID Scrounger's Avatar
ID Scrounger
I love the big sixes but even after dumping a ton of money into them they still are struggling to do what a bone stock 2 barrel 390 does. It takes a certain blind eye to money spent vs power gained and a true love of the big six to build one up.
On the other hand I have a love hate relationship with the FE's--I love how simple they are but I think that intake manifold design deserves a special place in hell.
If you're looking for pure bang for the buck I'd go with the 390 that you already have. I have a new never mounted Performer RPM FE manifold sitting in my shop if you have any interest...I'd let it go much cheaper than a new can be bought.
Old Aug 12, 2016 | 01:51 PM
TA455HO's Avatar
TA455HO
Lead Gopher
It would be a shame to mess with a Ranger too much, but then tempting to replace the 240. Tough choice.
Old Aug 12, 2016 | 02:14 PM
markeyd's Avatar
markeyd
my 66 f-100 has a 390 with a c6, and I like it . . . if you are worried about originality for value's sake then keep the original engine somewhere if you do the swap so you can always say you have the original engine if you do go to sell it.
Old Aug 12, 2016 | 03:32 PM
charliemccraney's Avatar
charliemccraney
Since swaps are supposedly quite easy in the later slicks and you already have a donor, then the 390 may be a good way to go.
I haven't seen the other posts but I don't see a complaint here about the 240. If you're generally satisfied with it, then upgrade it, dare to be a little different.
Old Aug 16, 2016 | 07:42 PM
RangerMercMan's Avatar
RangerMercMan
I would yank the six and stow it away and put the 390 in it. Easy to swap back later on so long as you keep it all
Old Oct 29, 2016 | 01:09 PM
1966f100ranger
6 months later, after building my savings account up, started tearing into the motor, turns out once measuring the stroke of the supposed "390", it was a 360. Sorta pissed off, but I can always make it into a 390. As far as the manifold goes, yes I agree they are terrible. I have a holley 650 cfm in my garage that I could put on. What would you want for the edelbrock?
Old Oct 29, 2016 | 02:35 PM
The Masked Rider's Avatar
The Masked Rider
Yes, but mainly for the weight. The WOW factor won't be noticed unless you change or at least modify the heads. What are the #s on the heads. If you can find a good pair of early model G heads and install the larger cobra valves, I think you'd be happy. OR, spring for a set of aluminum heads to match the manifold.
Old Nov 29, 2016 | 07:48 AM
ftrk66's Avatar
ftrk66
I am interested in swapping my 300 I6 to the a V8 more like the 390 you have.
But what Ford truck or car model that engine came on. Thanks.
Old Nov 29, 2016 | 11:42 AM
daveengelson's Avatar
daveengelson
IMO, mentioned the 240 " runs great" then I would not go the expense of purchasing headers; not an authority just not sure the 240 would reach the power band where headers play a factor? I would install a decent exhaust system and either route them out the back, or behind the rear wheel. Again, if the engine is running great, then I would stay with the existing intake and carburetor, swapping for a 4bbl, IMO, would be a waste, doubtful the secondaries would come into play? If decide to swap for the 390 then upgrades may be another matter, not so sure with swapping for the 302?
If intend using on a regular basis then there is a significant difference in MPG between the 390 and 302?
Imagine, all things considered, the cost would be minimal if decide to stay with existing configuration; meantime, drive the truck while deciding and do the research on what would be involve; cost, and benefits? Anyhow, food for thought?
Old Nov 29, 2016 | 03:28 PM
charliemccraney
Any engine can make use of better exhaust (headers), bigger carbs and corresponding intakes as long as complimentary modifications are made.
Think of a 240 6cyl as 3/4 of a 320ci 8 cyl. On a per-cylinder basis, the 240 will have the exact same demands when everything that can be equal is equal. The exact same things you would do to this hypothetical 320 will apply to the 240. The laws of physics are the same no matter the displacement or number of cylinders.
Old Dec 1, 2016 | 02:39 AM
ftrk66's Avatar
ftrk66
So the is no much of a power gain if I go 302/390 V8 engines copmparing to the I-6, 240 or 300?.
Old Dec 1, 2016 | 07:00 AM
john jamieson's Avatar
john jamieson
I don't know about the 302, but there is a big difference between a 240 and 390. The 390 is 60% larger. What are you primarily going to use the truck for?
Old Dec 1, 2016 | 08:10 AM
ftrk66's Avatar
ftrk66
I just wanted a V8 so I can go 70-80 MPH, I do a lot of long distance driving.
