I was looking to see if someone could tell me the proper procedure for installation? Do these just bolt on or do you need to run a dab of sealer around the edge. Mine are all cracked from the sun and need to be replaced.
Sure here is a picture of it on a single cab, mine is an extended. Roof is getting repainted and I have these parts ordered to replace the sun damaged cracked one. I just need to know how to replace them properly.
Although I have not changed one I would assume they kind of pop or snap in. Once you get the truck back from paint you will need to take the cracked one out anyway so then you'll know how. I'll guess they pry out and the new pops back into alignment holes. gary
