Different PCM flash, TEE5 to ???
Old 08-09-2016, 01:13 PM
fordguy390's Avatar
fordguy390
fordguy390 is offline
I have a 1995 F-250 7.3 with TEE5 flash and have read some forms about this flash and wondering if anyone had the TEE5 flashed to something else.? I knonw Jody from DP flashes them. I have a TS chip with what i think a newer flash code on it. Without the chip the TC unlocks when i let off the go pedal and with the chip in and on stock TC is locked till brakes are applied. What flash do you all recommend?
Old 08-10-2016, 08:37 PM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
Dumb question but why are you taking the chip in and out??? Just leave it in and save yourself the $100 from the reflash.
Odds are your chip is TDE0 or TDE1, which had the good TC logic that keeps the TC locked.
I'm convinced that the poor trans logic that unlocked the TC everytime the IVS switch closed is what ruined many a trans.
So, if your still planning a reflash, go with TDE1.
dcelrod
10-21-2015 11:28 PM
Spool&Go
10-29-2014 10:35 PM
AzPatMan
Computer Chips & Tuners
05-16-2013 01:09 PM
papadelogan
13
12-10-2009 08:41 AM
foxracing0934
07-02-2009 05:12 PM
Quick Reply: Different PCM flash, TEE5 to ???
