1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Crank No Start, 2004 F350 6.0
Old 08-05-2016, 08:18 PM
bigalsmith102
bigalsmith102 is offline
bigalsmith102 is starting off with a positive reputation.
Hello Everyone!
I've recently bought a 2004 F350 CC LB 6.0 truck, and I love it. It ran awesome, up until Sunday of this week. I went out to start the truck, and it cranked but didn't start. I thought I hadn't let the glow plugs cycle. I turned the key off, waited 10 second, cranked, no start. I thought about it for a while, tried again, and is started!? What the hell!?
I drove it 20 miles and parked it. We had a good time at the beach with my family. We got back in the truck and it started instantly and we drove home.
The next day, crank, no start. Crank, no start. And that's where I am now. Cranks awesome, doesn't fire off.
I know there are a lot of different reasons why this may occur, ranging from all different sorts of issues. I want to go about this in a methodical way, and so I've come to you guys for help.
I've checked both batteries independently and got 12.5+ volts from each one. That's as far as I've gotten.
I borrowed a Snap-On SOLUS scanner from my friend, and hooked it up to the OBD-II port and selected "CODES MENU" and ran a KOEO SELF-TEST and received the following codes:
P0261, P0264, P0267, P0270, P0273, P0276, P0279, P0282. (All 8 read, CYL INJECTOR CKT LOW)
Next, I selected DATA DISPLAY, then DRIVABILITY and received the following figures: (All while KOEO)
APP% 0.00
APP1 4.03
APP2 1.48
APP3 0.92
APP_LOW (V) .52
ARPMDES 0
BARO ("Hg) 28.9
BARO (Hz) 157
CMP_FAULT NO
CPP/TCS ON
DSD (RPM) 4080
EBP (V) .91
ECT (*F) 70
ECT (V) 3.86
ECT_FAULT NO
ENG LOAD(%) 0.0
EOT (*F) 68
EOT (V) 3.86
EOT_FAULT NO
EBPDSD ("Hg) 3
EXH_BACK_PRE (PSI) 14
FDSP_EDC3_GPL OFF
FP (%) 0.00
FPM OFF
FICMLPWR (V) 11.5
FICMMPWR (V) 48.5
FICMSYNC NO
FICMVPWR (V) 11.5
IAT (*F) 90
IAT (V) 2.79
IAT2 (*F) 90
IAT2 (V) 3.84
ICP_DSD (PSI) 0
ICP_PRESS (PSI) 0
ICP (V) .25
INJ_PRS_REG (%) 15
INJ_TIM (*) 0.0
MP_LRN YES
MAF (V) .05
AIRFLOW (g/s) 0.00
MAF_FAULT NO
MAP (PSI) 14
MFDES (mg) 0
MGP (PSI) 0
PIP_CTR 0
PIP_HIGH HIGH
PIP_LVL OFF
PNP P/N
SYNC NO
TORQUE 0
TP_FAULT NO
TPCT (V) .52
VFDES (mm^3) 0
Can anyone please suggest which direction I should take this diagnosis next? Thanks in advance!
Old 08-05-2016, 08:25 PM
bigalsmith102
While I'm waiting for your awesome help guys, I decided to run FUNCTIONAL TESTS --> INJECTOR BUZZ TEST.
The scanner came back with the same codes present in the KOEO SELF-TEST, that being:
Old 08-05-2016, 08:39 PM
texastech_diesel
texastech_diesel is offline
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
What are all of those, but at hot idle once it's run to where ECT is 190+*F?
Old 08-05-2016, 08:48 PM
bigalsmith102
As the truck is not starting, thus I'm not able to run it, I can't check the data sets where ECT is 190+*F.
How hot will my block heater get the coolant up too? Is it worth a shot plugging it in for a few hours, then running the tests again?
For reference, on Tuesday, I did plug it in overnight and I got the same "Crank, No Start" condition.
Old 08-05-2016, 09:30 PM
texastech_diesel
Your post seemed to say it was running intermittently. What's ICP_DSD, ICP_PRESS, ICP_V, INJ_PRS_REG and FICMMPWR when cranking?
SYNC should be "YES" or "1" at some point while cranking also.
Old 08-05-2016, 10:26 PM
bigalsmith102
I'll have to get back to you with the answer to this. I need to let the batteries sit on a charger for a while, as I managed to drain them well enough to no longer crank.
Old 08-06-2016, 02:04 AM
bigalsmith102
Truck started...
I had the batteries on a charger at 10amp for an hour, and 2amp for 2 more hours after that.
I turned the key and the truck cranked over very fast but didn't start. I cycled the glow plugs a second time, and the truck fired up! It idled well initially, but then started to idle a bit rough at which point I decided to stop annoying my neighbors at nearly mid-night, and shut the truck off.
Unfortunately, I did not have the scanner on, and was not able to check the ICP_DSD, ICP_PRESS, ICP_V, INJ_PRS_REG and FICMMPWR
I'll fire it up in the morning (hopefully), and hit it with the scanner to get those numbers for you.
The batteries are both new as of 7/14 (according to the stickers on the batteries), but the previous owner was quite upfront in that he didn't drive the truck much in the past 9 months, a it has only been driven about 12k miles in the past 4 years. This would lead me to infer that the batteries have NOT been well maintained, and may have been damaged after sitting so long.
OR, the batteries are totally fine, and the alternator is not charging correctly. I'll check the alternator output tomorrow while it's running, (provided I get it started again), and I'll have to have the batteries load tested at an auto parts store as well.
I hope to take care of this first thing in the morning, but I'm headed to an early afternoon wedding tomorrow so I might be partying too hard.
Thanks for your help!
Old 08-06-2016, 03:07 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Congratulations, and Best Wishes to your bride!
Old 08-06-2016, 11:05 AM
bigalsmith102
ICP_DSD = 756
ICP_PRESS =766
ICP_V =.95
INJ_PRS_REG = 30
FICMMPWR = 13.5-14
Old 08-07-2016, 09:12 PM
bigalsmith102
With ECT at 181*F while running
APP% 0.00
APP1 4.03
APP2 1.49
APP3 0.92
APP_LOW (V) .52
ARPMDES 0
BARO ("Hg) 28.9
BARO (Hz) 157
CMP_FAULT NO
CPP/TCS ON
DSD (RPM) 640
EBP (V) 1.18
ECT (*F) 181
ECT (V) 1.31
ECT_FAULT NO
ENG LOAD(%) 24.7
EOT (*F) 180
EOT (V) 1.30
EOT_FAULT NO
EBPDSD ("Hg) 5
EXH_BACK_PRE (PSI) 17
FDSP_EDC3_GPL OFF
FP (%) 100.00
FPM ON
FICMLPWR (V) 13.5
FICMMPWR (V) 49.0
FICMSYNC YES
FICMVPWR (V) 13.0
IAT (*F) 111
IAT (V) 2.20
IAT2 (*F) 131
IAT2 (V) 2.63
ICP_DSD (PSI) 580
ICP_PRESS (PSI) 579
ICP (V) .82
INJ_PRS_REG (%) 23
INJ_TIM (*) -3.8
MP_LRN YES
MAF (V) 1.49
AIRFLOW (g/s) 31.62
MAF_FAULT NO
MAP (PSI) 15
MFDES (mg) 9
MGP (PSI) 2
PIP_CTR 3
PIP_HIGH HIGH
PIP_LVL OFF
PNP P/N
SYNC NO
TORQUE 33
TP_FAULT NO
TPCT (V) .52
VFDES (mm^3) 11
Do these numbers look good?
I bought a SCAN GAUGE II today as well and hooked it up. No codes from it. Alternator is charging at 13.4v and batteries were both load tested and were pronounced in good condition.
Truck currently starts and runs great. No problems now. I'm just paranoid I guess and would love to have some reassurance if anyone thinks these numbers look good.
Thanks!
Tugly
173
02-12-2019 11:57 AM
Fbg
04-06-2017 07:53 AM
Flaman
02-26-2017 07:10 PM
fordpride
15
05-23-2016 01:00 PM
texastech_diesel
03-07-2016 09:54 PM
Quick Reply: Crank No Start, 2004 F350 6.0
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
