time for a new seat. my 90 has 216,000 miles on it and i need to have my seat or reupholstered. founf a seat at pick-a-part in a 87 dually, captains chairs and center console. i can get the whole setup, mech and all, for $100.00. d have to have them reupholstered, im sure it would cost a pretty penny. right now my bench is adjusted all the way back. my concern is that the captains chair seems to be thicker than my old bench seat. i dont know how much closer ill be sitting to the steering wheel. anyone done this swap.
mine is a regular and the donor is a crew cab F350
That should work then. But I've seen some "very redneck" installs of bucket seats, so inspect how the mountings are done before buying. The factory approach works very well and leaves you with easy and (junkyard) plentiful options for replacement. (i.e. lots of common Fords with bucket seats sharing the same bolt-pattern.)
what kind of truck is that "captain's bench" out of? Mine has a bench seat and I don't want to mess with adding bolt holes towards the center of the floor.
I tried to reply to your PM but your settings won't allow it. But in short, get the tray and tracks for $100 and then you can chose from thousands of Ford seats at the junkyard.
