1995 7.3 swapping into 1996.5 f350 help
New to this site. I have a 1995 f350 crew cab with a 7.3 and auto. Rust took over so I bought a 1997 f350 crew cab 7.3 5 speed rust free no drive train to swap my 95 running gear in to. Door says manufactured 1996 and month 6.
I have it all hooked up but have no throttle response. The check engine light on. I hook a reader to it and it reads data link connection problem.
There is a wire gray with red stripe on the 95 engine is believe to be a 5 volt wire to the sensors, when it gets battery voltage of 13 volts and starts to smoke and melt wire. I have to cut wire in half to make idle. If they touch engine dies instantly.
I cannot find a color coded wiring schematic that can show me which pins need to be moved to make this all work.
Please help
Please help
None were cut. There just seems to be a difference between the 1995 engine and connecting it to the 1996.5 chassis. It runs and idles fine. No throttle response. Thank you for the diagram.
Webasto 9.1KW
04-26-2018 04:31 AM
RES94025
07-17-2005 02:15 PM
dieselnovice
11-19-2004 11:03 PM
