FE Head Gasket Bore
Go with the 4.165, with a 4.080 bore the 4.080 head gasket would have to have prefect bore spacing and be in perfect alignment on the dowels, if not the wire ring sandwiched in the gasket may not seal properly and you'll blow a head gasket.
I'm a little confused about cutting a valve relief in the bore for a CJ valve, I've ran CJ valves in several 390 engines and never had to cut reliefs.
Nick-1973-ford
01-04-2017 09:02 AM
FoothillFord
06-15-2008 08:49 PM
powderspecial600_98
01-11-2006 10:06 AM
76 F150 Ranger XLT
09-14-2004 10:23 AM
