I have a 400 8.8 cp, edlebrock 1405, edlebrock performer intake.
I have a regulator set at 5.5 psi.
Want to get away from the mechanical pump, looking for a good dependable electric pump
Carter 4070. It's dead reliable and quiet. I'm running one as a lift pump to feed the surge tank on a fuel injected motor. Itll be plenty of fuel pump unless you have a wild built engine. Most parts stores can get one or you can order from summit or jegs.
I could not find this one one Summit , I did find this one.
I found it on summits site. Try part number crt-p4070. It looks identical to the one you linked but the 4070 puts out 72gph flow vs 50 from the one you linked. It said it would ship today so they have them in stock.
Does the extra capacity make a difference in a (relatively stock) carbureted engine? Like, maybe runs cooler or something like that? Longevity?
The 72gph unit is only like 5 bucks more...just wondering if there was an advantage to it.
Seeing this post is tied in to electric fuel pump,I wrote fitec asking is it better to have a submersible pump vrs a frame mounted electric pump,,,,their answer was its always better to have an in-tank pump,,your thoughts on this subject
Submersibles run cooler and last longer and are pretty much required equipment on a FI engine where the fuel pressure required to run the injectors is much (MUCH) higher.
They're also expensive and require unnecessary surgery on a carbureted application.
Yes in tank will be cooler. The reason why I want a frame mount is in case Im off roading with someone and I need some gas or something I can pull the fuelline easier to get fuel.
I remember wheeling with my dad back in the day and he pulled the fuel line so he could use it to pour into another persons carb to get it to run.
If though I carry a extra gas can, It might be nice .
