Flathead Radiator 1953 V8 F100 (flathead)
Does anyone have any experience with using a radiator made for the 52 and earlier model V8s in a 53? I need a new, or better condition rad. to replace mine. The replacement Flathead rads I see, are at least twice as much for the 53 as they are for earlier years.
It has been a while since I have posted anything here. my computer is slow to load pages, so painful to spend time here, is it worth while to upgrade?
The 53 is most likely a one year only radiator as Ford went to the new wider cab design yet kept the flathead V8 with four coolant outlets in 53. I no longer own a 53 or later but I believe the radiator is wider in the 53 and later than they are in the 52 and older. If I am right, brackets could possibly be made to make it fit. Just my before first cup of coffee ramblings.
raytasch you are correct, 1 year only for that combination.
$165.00 (1950-1952)with free Shipping. vs. $350.00 ($315.00 + $35.00 Shipping) (1953)
And for 2 outlet (1953-1956) $159.95
Big hit for the xtra 2 outlets.
50 51 52 Ford F1 Pickup Truck Flathead Champion 2 Row Aluminum Radiator EC4252FH | eBay
1953 1954 1955 1956 Ford Truck F 100 Radiator Aluminum for Ford Flat Head Motor | eBay
1953 1954 1955 1956 Ford F 100 Pickup Truck 2 Row Champion Aluminum Radiator | eBay
Hi ALBUQ F-1,
Radiator is in poor condition, multiple tubes are corroded through. Top tank is badly dented, Many previous repairs.
There was one good Radiator shop in my area, and now they seem to be struggling.
Not sure what it would cost to get this radiator back in shape, re core? cost?
Where : 900 horsepower (hp)
Equals : 2,289,989.90 btu per hour (btu/h)
Fraction : 2,289,989 9/10 btu per hour (btu/h)
call it 1.2 million BTUH into the radiator
Q = heat transferred = 500 x GPM x dT
Let's say the water pumps flow 20 gpm
Solving for delta-T (dT), the change in temperature from inlet to outlet,
1.2 x 10^6 = 500 x 20 x dT
dT = 120 degrees
So if water goes into the engine at 140deg, it comes out at 260 deg.
Don't think so....
