Exterior backup Alarm
Of course. The up fitter switches can be used for any 12v accessory.
you could use up fitter to provide power for a relay, reverse signal wired into relay as well and output of relay to reverse alarm...
I have my air horns wired up the same way with the signal coming from the horn and up fitter providing the power to the relay.
Yes i frame mounted the compressor and tank (per EpicCowlicks instructions on youtube) It really worked out nicely. I think on my new truck i may put the compressor and tank in the bed (should have room under the rolling bed cover can near the front). With the new boxed frame i have a feeling it will be a PITA to try and bolt anything onto it.
I live in south texas so my truck has seen snow only on my trip to cincinatti. The intake for the compressor is in the cab so really everything is holding up great.
I have a 5 trumpet set I purchased years ago...I had them on my shop and when Mrs went out for a walk I could annoy her up to 2 miles away. Plenty loud and a very "Sweet" sound. I will try to find the brand but think that is long ago lost. One of the advertising points was tuned to sound most like a train. They do. Sometimes toot at the train which runs close to the back of my shop and usually get a toot back unless new engineer who gets overly startled at the thought of cross traffic.
I have a Timex Indiglo battery powered alarm clock I use if it is really important I get up. I set it to ring 10 minutes after my primary alarm. It always pays to have a back-up.
I would go to a heavy duty truck or construction equipment supplier and see what they have available. There are different sounds available. Personally, unless required by law because of business, would just be extra careful. I hate backup alarms and on a construction site they are so common that people become immune to their sound. I won't go to McDonalds even for just coffee because of the ear splitting alarms which allowed to ring and ring. Maybe I should get a job there for a while and then try for a settlement due to ear damage.
Why not the one from Ford?
BAD RONALD
1997-2006 Expedition & Navigator
21
10-25-2017 08:45 PM
OoMesKoO
03-21-2010 06:19 PM
