6.8L 2wd popping noise from tranny
Hello, TIA for the help and ideas.
My 01 Excursion Limited 6.8L 2wd is having what I think is a tranny / shifting issue? Mileage is about 160K. She has been doing just fine and no recent work or out of the ordinary maintenance / replacements..
Got in her this morning to go and noticed that the tranny seemed different. First thing I noticed was that the shift form 1 to 2 was long in coming and then sort of hard / thump when it did change. Then is seems to rev higher in the rpm range than normal when going into 3rd maybe 4th.? I pulled over into a parking lot, turned it off and did a brief inspection of the underside, fluid, etc.. and did not find anything strange. Started her back up and went to leave when I heard a popping / thumping noise from the tranny. Threw it in neutral and reved the motor to see what it sounded like and it was good. Back in drive again and the noise was there. Seemed to go away after getting up to say 45/50mph but the shifts were still off. Took her back home and now trying to decide whats first on diagnosing this issue?
Thanks
Thanks
The places that read codes free CANNOT read all of the codes you need. You need either a good independent shop or a Ford dealer.
duc_grrl
General Automotive Discussion
10-24-2005 09:47 PM
Vampiro
05-29-2002 12:30 AM
