6.0 Where is my coolant going?
Hey Everyone,
2006 6.0l
Just noticed yesterday during an oil change that I had white stuff around the coolant cap on the overflow bottle and that no coolant was visible. I went and got some antifreeze premix to top it off and it only took around 1 quart. Today after driving it approx 30 miles, the coolant was again missing.
When I changed the oil the other that same day there was no coolant in it, and I don't have any puddles on the ground. Any idea's whats going on?
EGR is deleted with a sinister kit, temps are fine, today it was 94 degrees and the truck was running at 194 oil 192 Coolant when getting off the highway after 15 minutes doing ~75.
I've got a little bit of stiction going on but besides that nothing seems wrong.
Denis
2006 6.0l
Denis
Hope you topped it with something other than green coolant.
With a delete already in place, I'd suspect you have a head gasket issue. Get the truck up to temp, carefully relieve the pressure off the cap and then drive it some more, being careful to not work it hard, just normal driving. Then try and relieve the pressure again after a little bit. If there is pressure, like a decent amount, I'd say heads.
Tried smelling the exhaust or notice white smoke?
It might not be the cap at all.
Hi there, don't want to hijack, but what do you mean by this? I have coolant puke in my EGR deleted 6.0 but I really don't think it's gaskets as the truck runs like a scolded dog and there's no smell or smoke. Just puke. I hear the vacuum coming on a lot of the time when I start the truck so I'm wondering if the two are related?
FWIW---my 6.0 dynoed 476 rwhp with blown headgaskets. If your EGR cooler is gone and you're puking they're more than likely blown. Try a coolant cap first because once they pop they're done. If it still pukes then get ready....
Not sure about your EX having a heater control valve, although I bet it does, but it's on the heater line that runs from the alternator bracket to the firewall and has a gray vacuum line running to it. Occasionally they leak.
Would the heater control valve leaking cause the puke in some way? Thanks much.
Well I'm wondering if I'm already two years into it honestly. I've been dealing with coolant issues for some time now. I've replaced the y pipe, the degas bottle itself, replaced the oil cooler (for another reason) it's not a tremendous amount... maybe 1/4 - 1/2 gallon every 1500 miles and I swear the truck runs the exact same but maybe it's time to do the check.
It very well could be something simple. Have you checked the valve going to the heater core? I also had a strange one. My water pump was bad and would only leak just after shutdown--not driving and not when cooled down--just after shutdown. Only way I found it was I was jacking it up to do front end work. But for me I'd change the degas cap, check the galley for any wetness, check the valve in the heater hose going to the heater core, all connections, rad drain, all hoses. If nothing do a pressure check on the cooling system. Frankly if your not puking you have a leak. If you are puking.....there you go if all the above has been looked at.
