Problems after a medium burn-out.
Old Jul 26, 2016 | 07:13 PM
Kyre Searcher's Avatar
Kyre Searcher
No new news on what the problem is, I checked all the hoses on the tree behind the carb where the break booster connects but found nothing that looked old or weak,,
On another note tho, I got the idle down as far as I could without it dying when put into gear because I had to test drive it a bit because I have to take it to work tomorrow. I noticed that when I (got on it) it has more power now than it did before the problem. I have a step hill I go up and every day with pedal to the floor I can only get about 45 mph, today, I went up the hill and was closer to 60 mph, and I could feel the noticeable difference in the power, but as soon as I let off the gas the engine starts sounding like it has a miss. After work tomorrow I will go thru all the rubber stops and check them all.
Without a doubt tho, some kind of leak is going on near or around the break booster vacuum line at the tree.
Old Jul 26, 2016 | 07:14 PM
Franklin2's Avatar
Franklin2
If your holley has the fuel level site plugs on the front and back side of the fuel bowels on the pass side of the carb, pull them and see what the fuel level is.
Horsing around with the truck can stir up dirt and rust flakes in the gas tank, and they can get sucked up into the carb and cause problems. Rusty gas tanks are a common problem with these trucks.
Old Jul 26, 2016 | 11:44 PM
kr98664's Avatar
kr98664
Check your motor mounts. All that torque may have caused one of the mounts to separate. If the motor twisted, it could have kinked a fuel line, pulled on some wires/vacuum lines, or tweaked the throttle linkage.
Old Jul 27, 2016 | 06:13 PM
Kyre Searcher
Checked the fuel bowl levels, they ( front and back) are just about an 1/8 inch under the sight hole. Fuel line has not been bent or leaking.
any more idea's? I have been trying to use the pigtail to pull codes but it does not seem to work at all. Im stumped.
Old Jul 28, 2016 | 08:23 AM
Franklin2's Avatar
Franklin2
What intake manifold are you running? The original factory one with the EGR on it? Is it disconnected?
Another thing to try; While it's running, with the aircleaner off go around to the pass side and fiddle with the lever that goes from the secondaries up to the secondary diaphragm. If I remember right there is a phillips screw that holds the lever onto the secondary shaft. While it's running loosen this phillips screw a little bit and see if the idle goes back down. I have had this linkage get sticky and crack the secondaries too much.
The secondaries on a holley are opened just a little bit all the time. This adjustment is a screw that goes through the baseplate up from the bottom, you have to take the carb off to adjust it. The screw stops against the dog with the phillips screw I was talking about. I would not mess with the adjustment, but I would make sure the linkage is ok and loosen that screw and then re-tighten it to see if it makes a difference.
Old Jul 28, 2016 | 04:56 PM
Kyre Searcher
Im not sure about the intake manifold, I will check the throttle for the secondaries next tho. Here is a video of the truck and engine, but this video is older, I made this video when the carb was clogged and I was trying to figure that out, but you can see most of the engine
Old Jul 29, 2016 | 12:04 PM
Kyre Searcher
OK, guys, Problem has been solved.. I was almost certain it was a vacuum leak because of the burn out I did that caused it.
I took it to a local shop today and had a guy look at it, we took the air filter off then he asked me to start it up, I did and the idle again still very high, he hit the throttle 2 times, leaned in and put his ear next to the carb and told me to shut it off, I did...He told me the test port plug sounds defective or gone and felt behind the carb and said...gone... He put a new plug on it and asked me to start it up again, I did and it was back to running perfect again.
Thanks for all your help and your time. You guys are awesome !
Old Jul 29, 2016 | 12:49 PM
FuzzFace2's Avatar
FuzzFace2
Good to hear you go it fixed.
Got to ask what is this "test port" you talk about?
What does it test?
Dave ----
Old Jul 29, 2016 | 01:00 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I was going to ask the same thing Dave.
I think Holley provides that port for PCV.
At least that's what I use it for.
Old Jul 29, 2016 | 03:55 PM
FuzzFace2's Avatar
FuzzFace2
OK first time I have ever heard it called a test port
In the base I would also think a PCV hose hook up.
Dave ----
Old Jul 29, 2016 | 05:30 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Dave ----
I'm not sure which model 600 cfm Holley he has.
On my 0-80457s, there is only one nipple and it is to be used for PCV or brake booster.
The instructions are under 'tech resources'
https://www.holley.com/products/fuel...parts/0-80457S
Kyre Searcher
17
Jan 29, 2015 05:10 PM
rob-o
Jul 14, 2009 06:55 AM
RussianWolf
Sep 26, 2006 02:16 PM
Scotter06
Jan 15, 2005 02:34 PM
trixie
Jan 16, 2002 07:20 PM
