1997 Explorer - fuel fill SLOW!
Hello all-
My '97 Explorer is struggling to take on fuel at fuel fill.
Started all of a sudden...At gas station last week I inserted nozzle and attempted to fill tank as I normally do. It would not accept fuel at a fast pace. It keeps clicking the gas pump trigger off. I keep squeezing and it keep clicking of every 1-2 seconds!!
What can this be?
What steps can I take to analyze before I start replacing parts at random?
Thanks
What can this be?
Thanks
So I did a bit more looking through the service manual this morning. There is a vent hose that is attached to the fuel tank, just a couple inches away from where the filler neck/tube connects to the fuel tank. I suspect this is the smaller hose that connects to the underside of the fuel fill tube and would normally be covered/protected when the fuel cap is installed. I'd now suggest starting by disconnecting that vent hose from the fuel tank, remove the fuel fill cap, then blow some regulated, low pressure hose from an air compressor through the tube from the tank end. That vent tube is likely restricted.
Has any body work been performed in that area recently that might have kinked or pinched the vent tube?
-Rod
-Rod
Start with the filler neck/vent tube assembly and tank connections. Based on the symptom described this is where I would focus my efforts to begin with.
The one valve used on that particular tank is a Fuel Vapor Valve. It doesn't appear that it would prevent refilling of the tank.
Fuel tank layout...
Filler neck/vent tube assembly...
Hope this helps.
Fuel tank layout...
Hope this helps.
2Wise4aGM
16
12-21-2015 07:09 PM
nisvec22
12-17-2012 01:04 PM
