Tranny issues and throttle jacked
So I made a previous thread about replacing the shift forks. We got the replacement forks and about to put it together. The only thingthing is I was told to put it in neutral after I had already taken in apart. It may be in some random gear or could be in 2 gears at once... here's a picture of it. Don't know what to do or how to get it in neutral and be able to get the cover back on....
Gear picture
Also when the truck is running the throttle is hard to push and when it finally moves it goes up to 2500 rpm or so. I have no way to feather the throttle and when you have a manual that's unacceptable. Could be the cable but I'm not sure. Whatever it is it makes in undrivable. Please help as I need to get it out and running sometime today!!!
Gear picture
My bad... It'sa 93 F-150 XLT With the 5.0 302 in it and the tranny is the M5OD R2. I just lined the shift forks with the shift collars and put it all back together. Shifted through all the gears a few times to make sure it was solid and started it up and drove just fine. The throttle I'm still having issues with though. Sticky and hard when running and feels fine when the truckis shut off.
Nothing to do with being clean. The throttle stop screw is there to prevent the blades from closing too far which results in them mechanically sticking in the bore. Inspect that screw to see if it looks like it has been moved. Usually you can see where thread locker was applied from the factory.
Well I adjusted it and backed it off a little bit. The issues were on the top of the throttle body you have those springs and crap on the top that actuates the butterfly flaps. Sprayed some WD40 and seems to be good now. It idles at about 800 and throttle response is great now.
