Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Reload this Page >
lifted 2000 f150 with bad lean to driver side
Old 07-21-2016, 03:12 AM
cglow1
cglow1 is offline
cglow1 is starting off with a positive reputation.
Hey everyone, I have a 2000 f150 with a 3 in body lift and a 3 in spindle lift that was always level up until i let my roommate borrow it. He claims that he hit the center divider with both front left wheel and rear wheel doing 40 mph. The truck had both wheels on the divider.. After he told me this, i looked over the truck and found that it was noticeably leaning to the driver side. To make it short: I replaced lower a arm, replaced shock and put in new sway bar bushings, but it is still leaning..The whole truck is leaning to the driver side, not just the rear, front too. The difference is about 2 in front and back..Is it possible the frame got bent, or is it more likely the leaf spring is damaged? No visible damage can be seen and they were able to align it with no issues... If it is the spring, can i use a shim or block to level it, or should i get a new set of springs all together.. Any Input will be appreciated
Old 07-21-2016, 10:05 AM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
Sam I Am has a very good reputation on FTE.Sam I Am has a very good reputation on FTE.Sam I Am has a very good reputation on FTE.Sam I Am has a very good reputation on FTE.
Was he sliding sideways when he hit it?
Old 07-22-2016, 08:39 AM
Travis S's Avatar
Travis S
Travis S is offline
Travis S is gaining momentum as a positive member of FTE.
If it is both the front and rear left corners that are 2 inches lower than the rest, I would suspect frame damage too. However, it would also be discernible with buckled sheet metal on the body, such as on the floor pans. this is due to the dimensions between mounts changing as a result of the frame being distorted.
Go over the ENTIRE truck's cab & bed with a fine-tooth comb, looking for any wrinkles underneath. Bed would be more visible from the top
vortec 1
1999 to 2016 Super Duty
536
11-28-2018 10:44 AM
bismic
06-24-2018 04:02 AM
Kobra62
09-29-2017 07:50 PM
unlucky2.1_7.3PSD
07-19-2016 02:14 PM
jim4
02-15-2016 09:28 AM
Quick Reply: lifted 2000 f150 with bad lean to driver side
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
