HPOP Reservoir Level
Mark, I had something similar years ago, and what I did was remove the "check ball" mechanism. It's a 3/8 square plug, to the right of the hpop. Thought maybe something was in there, keeping the ball from totally seating. Since then(knock on wood) it's maintained that 1/2-3/4in fluid depth
I had an issue where mine had long starts that just got longer then no start. I would say 95% of the time the check ball is not the issue. I replaced mine and the spring. I could not figure out how to get the seat out. There is not an oring. Ford could not tell me how to get it out. Nobody else I talked to knew anything either. After months of trying to figure it out I looked down in the engine cover to watch for any oil leaking. I noticed a small trail coming out of the front HPOP seal. Someone else noticed in a pic that the seal had been pushed out. I sent the pump back to Joey at TE and he rebuilt it for me. No probs now. Up until that point no one else had posted anything like this on FTE that I could find.
BTW .... IIRC the check ball doesn't keep it from draining completely, which mine would eventually do. At some point it will quit draining if the fro t seal is good. Its called a quick fill check ball. I have pics of the back of the pump and chambers if anyone is interested.
https://www.ford-trucks.com/forums/1...-one-help.html
Post #48 shows where my pump was leaking. However this whole thread is a good read for anyone experiencing low hpop levels. There are pics of the check ball and oil passages. I went through the whole thing trying to find my problem.
frdf250
10-07-2017 02:49 PM
fordreaper
49
11-30-2010 09:54 PM
