Bazooka kicker woofer that doesn't need amp and other amp questions
Back in the 80s or 90s I remember a woofer that came out that didn't require an amp. By amp I mean one of those boxesthat power speakers
I thought the name of that amp was a bazooka and kicker me it but when I was looking online I saw kicker and bazooka are 2 different brands. Since I don't know what those kind of woofers are called I just searches for woofers that don't need amps. That didnt help
Does anyone remember the kind of ND who made the woofers I refer too?
The main e reason I don't want a woofer is they the up too much room but I thought I heard of one that fits in the Rm rest of an excursion. Does anyone know the me and model of that?
Bazooka makes two different types, an amplified one and a passive one. The amplified one has a built in amplifier, the passive requires an external amp to power it. You can find them here https://www.southernaudioservices.com/Tubes.aspx
I just got a kenwood dnx893s excelon head unit, and infinity kappa 50.11cs component speakers and infinity kappa 52.11l 5 1/4 " speakers for the rear doors.
I'll get one of those amplified Tubes.aspx you linked to unless there's such a thing as powered sub woofers that will replace the very back 2 speakers (is there)?
It's been a while since I've listened to one but from what I remember they had pretty impressive sound. There's no subs I'm aware of that'll replace your 2 back speakers. Either way, the sub will need to be amplified be it internally or externally so you don't have much choice there, you can either control the level to the sub from your head unit or they have an optional level control you can get to control the level https://www.southernaudioservices.co...ifer-P209.aspx so you don't blow the kids out of the car, and when the kids aren't with you then you can always crank it up like the old days. I think you should go with one of the amplified bazooka subs that have the internal amp so you don't need to install another component, then you'll need to run power, a ground, a remote turn on lead, and an RCA cable to it that'll plug into the subwoofer preamp outputs on your deck. The size of sub to get is dependent on the room you have for the sub and how deep of bass you want (the larger the sub, the deeper the bass). You have a nice head unit and I think adding this to your system will make a big improvement to the sound. Here's the installation manual for the 10" amplified if you're interesting in reading it. http://bazooka.com/pdf/current/Tubes...gualforweb.pdf
Actually, I've always been quite surprised that there haven't been more of the bazooka type "tube subs" out there, since they're able to produce some nice, tight bass and especially if you "corner load" them (have the woofer end pointed into a corner, which is often an installation spot that makes sense) they can kick out some pretty strong bass, especially when you factor in that you don't need to plop some huge sub box in the back that takes up a lot of room and is a PITA to remove whenever you need to haul something and need the room.
I've had several of them and I'm not part of the "must shake every car around me" crowd, just like some nice, tight bass I can hear AND feel and for that, they're perfect!!
