86 6.9 idi no crank
86 6.9 idi no crank
Alright well its been a long week of working on ny truck trying to get it running again. I changed the fuel filter and filled it. Went through and cracked a couple injectors and was getting preassure again but had to stop to let the batteries charge up again. So i tightend them and then went through and tried to start it again and she came close but didnt fire. So the next day same thing got preassure built up again good batteries and still didnt fire. Now my started just clicks and wont turn over. What is my problem? Starter? Vapor locked? Im at a loss. I have to get this truck movin again.
Thanks again guys
Thanks again guys
on
Getting any smoke out the pipe when trying to start?
What color?
Hows your Glow Plugs, have you checked them?
Starter clicking is bad/dead batteries, bad connections, bad relays or bad starter.
If you have a volt meter read this Voltage Drop Testing How-To: Fix That Slow Starter
-Enjoy
fh : )_~
What color?
-Enjoy
fh : )_~
Can you turn the engine over by hand using a large ratchet + extension + large socket (15/16ths on the gassers) applied to the crankshaft bolt? Gassers have a harmonic balancer there, no idea what a diesel operating on 30 yo technology would have there, might be the same.
But this kind of problem is gas-or-diesel independent.
on
6.9lbluenose
06-09-2019 07:48 AM
