Freeze plug leaking on back of engine block 300 i6
Earned 13 cents a day and was glad to have it.
Does anyone have any helpful tips for getting it out? I've been trying for 3 days straight, a few hours a day, and I can't get the stupid thing to budge. Ive tried everything from prying it out with a flathead screwdriver to grabbing it with a pair of curved needle nose and trying to wiggle it out but it isn't moving at all
That would give you something to grab with pliers or a nail puller type of crowbar, the kind with a fork on the end. You might have better luck near the edge of the plug instead of the center. Try several spots and see if you can get the plug to break free.
If you can't get it to budge by prying, here's another idea. Remove the lag bolt and get an extra long one of the same diameter, with threads running the whole length. Grind the tip partially blunt. Now thread this into the existing hole in the plug until it hits the opposite wall. Hopefully there is a relatively flat surface opposite the plug, and not too far away. Turn the lag bolt in a few turns and with any luck it will force the plug out.
To install a new plug, you could cobble together a custom clamping device. Cut two pieces of threaded rod a few inches longer than the cylinder head. Cut two pieces of angle iron a little bit longer than the width of the cylinder head. Drill a hole near each end to accept the threaded rods. Space the holes so the threaded rods just clear each side of the cylinder head. Thread a nut on each end of the rods, and voilà, a big clamp! Use a socket on the freeze plug for clearance. It might be a bit unwieldy to get started, so a helper might be needed. But once you get everything situated, you should be able to tighten up each rod a little at a time and press the new plug into place.
The following users liked this post:
I have a car that rotted a plug, replaced (with rubber type) and down the road another metal plug rusted out. Rubber plug down the road another rotted plug. Had think 4 go bad and the last is a bear to get to so the car sits till I can pull the motor as the trany font seal also leaks.
Pull motor and do all plugs now and be done with it.
Dave ----
on
I've had to many issues with rubber plugs, they always seen to fail in the most inappropriate time/place!
They work great temporarily, but don't expect them to last.
Also cleaning the bore & rubber plug 100% clean helps them stay in place, one good heat cycle and they bond and stick even better, any coolant on either and they like to pop out.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
-Enjoy
fh : )_~
-Enjoy
fh : )_~
It is hard to pull motor as there is little room to get to bolts, think 302 in a Mustang II type car.
Dave ----
Dave ----
Really?
But they are more commonly referred to as freeze plugs because if the block is filled with water and it freezes, all of these plugs will be ejected from the engine.
Now you know
Jim
#28
If you are lucky they push out when it freezes.
I got for free a 69 Bronco with a 302 / 3 on the tree because the block had water in it, it had a leak some where and he got drunk 1 night and forgot to drain it.
Well the block cracked and he did not want to deal with it.
I took the chassis added a few inches to fit under a 68 Cougar, add another 302 I had and I had a 4x4 68 Cougar.
Dave ----
Dave ----
#29
Dave ----
Dave ----
#30
