Engine "rattle" at speed...
Old Jul 14, 2016 | 07:53 PM
Connecticut Calvin's Avatar
Connecticut Calvin
See now this my good people is why the FTE is such an amazing source of info. Good people. Good intel.
Thank you so very much for your time to write all that. I learned a lot and I'm sure others did too. I'll start poking around to see what I can find.
Old Jul 14, 2016 | 07:55 PM
bigwin56f100's Avatar
bigwin56f100
Rod knock I'll put money on it
Old Jul 14, 2016 | 07:58 PM
Connecticut Calvin
Wouldn't I be able to reproduce a rod knock while revving the engine when parked?
Old Jul 14, 2016 | 08:06 PM
bigwin56f100
Rods rattle when there is no load and "revving" and engine doesn't give it a chance to have the no load, revving has power up load and deceleration load
Old Jul 14, 2016 | 08:07 PM
EBEAR's Avatar
EBEAR
Yes rod knock would likely be more noticeable when stopped due to no other conflicting noises
Old Jul 14, 2016 | 08:22 PM
raytasch's Avatar
raytasch
Believe Nothing
If it is a rod or multiple rods, raise the engine RPM slowly through the range to about half throttle and you will hear it. No load on the engine and it will be apparent.
Old Jul 15, 2016 | 04:44 PM
Mixer man's Avatar
Mixer man
Do you have a PTO? The PTO on my T98 will "rattle" when not under load. This is because of poor shimming to the case causing gear backlash rattle.
Old Jul 15, 2016 | 04:49 PM
Connecticut Calvin
No PTO. I wish I did!
At lunch I got the engine warmed up to 170. Oil pressure at 40 PSI. I slowly accelerated to 1000 RPMs (to the count of 5). Then let off the accelerator quickly. No rattle. I did it again but this time let off slowly. No rattle. I did the same at 1500 RPMs, 2000, 2500, 3000, 3500 and 4000. I never get above 4K RPMs so no need to go further since the sound, when in motion, occurs below this.
So I crawled under the truck and gave the drivetrain a wiggle. The U-Joint at the rear axle is solid. But up at the front of that same section it does this:
Old Jul 15, 2016 | 05:45 PM
raytasch's Avatar
raytasch
Believe Nothing
What is the condition of the center driveshaft bearing and the rubber that it is mounted in. There should be very little lateral movement in the driveshaft.
Old Jul 15, 2016 | 06:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If I hear what I think I hear in the video, metal on metal, the joint is likely dry and worn out. Hard to hear tho.
Old Jul 15, 2016 | 06:45 PM
Connecticut Calvin
The center driveshaft bearing appears rock solid. I can't wiggle the front driveshaft from the transmission to the center bearing at all. The only play I have is the front of the rear driveshaft where it meets that center bearing. That's what's in the video.
Old Jul 15, 2016 | 07:27 PM
Mixer man's Avatar
Mixer man
Ok, yep, that "rattle" you hear is those needle bearings rotating around the brinelling they've made in the cross that's been out of lubricant for awhile. Common issue on high mileage "permanently lubricated" universal joints. This could also be a latent issue from a previous owner(s).
Old Jul 15, 2016 | 08:13 PM
  #28
Connecticut Calvin
Okay a new universal joint it is! Obviously we can't say for certain this the source of my rattle noise but I'll replace it since it's bad and see if it goes away. Gentlemen: thank you!
Old Jul 15, 2016 | 08:24 PM
  #29
raytasch's Avatar
raytasch
Believe Nothing
If one is bad, the other joints probably are not far behind. Be sure to index the driveshaft parts before disassembly and install them in the same relationship.
Old Jul 15, 2016 | 09:10 PM
  #30
EBEAR's Avatar
EBEAR
It is human nature if not hot rodder nature to assume the worst but as I have been a mechanic for most of my life ( and I still do the same ) some times its not as bad as we think hope this is your problem
UNTAMND
Modular V10 (6.8l)
Sep 13, 2014 06:21 AM
r-kid
Jun 17, 2011 04:38 AM
TxFordGuy
May 31, 2009 02:28 PM
turboguy
20
Oct 21, 2005 04:54 PM
JnJ
1983 - 2012 Ranger & B-Series
Aug 3, 2003 11:21 PM
