51 F1 with R&P header choices
I was just about to put up a post on that piece. I have a 302 with and AOD. putting it together right now. I offset the engine 1" to the right to give clearance to the steering. (Volare steering box) lots of power was not my concern so I got the cast iron manifolds from summit. they look really nice in there. tons of clearance all around. and they should put less heat in the engine bay also. The issue I'm having now is trying to figure out how to connect it to the rest of the exhaust. but if you chose to go this route, maybe that problem will be solved in the post I'm about to put up.
steering shaft is not connected there but you can see how much room there is.
Small Block Ford Block Hugger Tight-Fit Headers, Plain - Free Shipping @ Speedway Motors
Jlwhitt77
10-20-2018 08:28 PM
Pokee
03-29-2017 04:12 AM
polarspeed
22
05-14-2015 03:09 PM
pageparsley
01-05-2004 09:49 PM
blatherskite
08-25-2003 03:22 PM
