Help with wiper for 64 ford 500
So have two questions here. First is regarding the windshield wiper. I have one but it doesn't work right now. Trying to figure out how to fix or repair the switch without buying another one as they seem fairly simplistic. what goes wrong with the switches and does anyone have some pictures of how the inside of one should look?
If it comes down to buying one where do I even get one? it's the single speed switch c3tb-17a553-g1.
Also is there a way to test the motor to verify if the motor might be the problem?
Second what is a ford 500? I see info on the f100,250, and 350 but can't seem to find anything about what a ford 500 truck is.
Thank you.
Thank you.
txking Welcome to :-X and the Slicks Forum.
The numbers start out with the 100 and go up. Each truck number it becomes more heavy duty. Your 500 is a 6 wheel truck, beds could vary, many with a flat bed 16-20 long. Someone more versed than me might splain it more better.
You can remove the wiper motor or bring a known hot wire to it to see if it turns. I had one out and placed it on the battery grounding it to the neg post and touching the pos where the wire connects and watched it turn.
That would be where I would start. It is my belief that they cab be swapped very easily. I had a 76 2 speed motor in my 66. I had to retain the original arm for proper parking.
Good luck with your hunt.
John
John
I'm assuming to swap to a 2 speed or what not requires both the switch and the motor? anything else to get it to swap? might you be able to use the original motor with a 2 speed switch?
Also does anyone by chance have a anything showing the switch being taken apart? I'm almost wondering if there are parts missing as it just doesn't look right in there.
I swapped from single to two speed. I changed everything, including the arms. If you search extensively you will find a partsbook page posted by ND which lists and describes the various lengths and applications of the arms. If you make the swap, it is critical that you realize left and right may be different lengths and that they aren't labelled...
Eric
Eric
The switches used are unique to single or 2 speed. So if you have a 2 speed wiper you need the 2 speed switch. I can't confirm for the later models, but the 61-66 ones are like this. I tried to add the later model switch with the integrated squirter to the old motor but the way the switch selects the 2 speeds is different and so it wouldn't work.
My parts book is a bit different to ND's and specifies a different arm for each side (66 only) prior to 66 they are the same part number. Whilst my truck is RHD, ALL the parts for the wipers are EXACTLY the same except for the bracket that holds it on the firewall. Even with the shorter arm on my drivers side, the drivers wiper still whacks the custom cab windshield moulding a little.
Just a thought. Might not be the problem you are describing but I took a shot at it, anyway.
C1TB-17540-A .. Left (drivers side) Wiper Arm-12 1/2" long / Use with single & 2 speed wipers / Obsolete
1961/66 F100/600.
C3TZ-17545-A .. Right (passenger side) Wiper Arm-12 1/4" long / Use with single speed wipers / Obsolete
1963/66 F100/600.
Pic: 17540 Applications from 1964/72 truck parts catalog.
turbohunter
01-24-2017 02:14 PM
Golfusaf
18
12-07-2014 03:46 PM
Tony_C
01-20-2012 12:10 AM
Narwhal
12-05-2005 02:14 PM
