Broke it DANG!
Jul 10, 2016 | 11:23 PM
Broke it DANG!
Well, I broke a filament on the blower motor resister.
I tried to solder but couldn't find my third extremity to hold the solder while my other two hands held the soldering iron and part.
I used epoxy but will that melt? Do the filaments get hot enough to do that?
Jul 11, 2016 | 12:03 AM
What kind of epoxy? JB-Weld is good to around ~500F, the blower resistors can get red hot.
Jul 11, 2016 | 09:16 AM
UGH!
Quote:
Originally Posted by
Tedster9
That's what I was afraid of. uess I'll just have to melt off the epoxy and get some JB Weld.
Thanks Tedster, Todd.
Jul 11, 2016 | 09:20 AM
Well, I dunno. It may be fine though doubtful. Maybe red hot is more than 500F as well. Why not just install a new one?
Jul 11, 2016 | 10:00 AM
old test lead alligator clips (roach clip) works great to hold wires together for soldering.
Jul 11, 2016 | 10:15 AM
I'd put a new one in. I'm guessing it's
this part or very similar. Probably a pita to do but it would be reliable. If there's no solder on the original, I wouldn't trust a solder repair.
Dan
Jul 11, 2016 | 10:20 AM
Well it's not a high tech part, if it works, it's a good repair.
Jul 11, 2016 | 12:35 PM
deckertd
Dan
Not the same. Mine, only has the 3 prongs together. No 4th prong ( loner ).
Jul 11, 2016 | 12:39 PM
MIKES 68 F100
Oh Mikes68F100!! Man I never even thought of those. It's been a long time since I used one of those, and it wasn't for soldering
I don't even think I have one laying around. What's a cheap chain ( Walmart, eg.. ) that would carry those?
Jul 11, 2016 | 12:43 PM
deckertd
Dan
You're probably right. I guess it depends on proximity and temp. How close to the joint the heat is and how hot it gets.
If I try the solder it will be close.
What size tip should I use?
Jul 11, 2016 | 08:08 PM
The MP of solder and JB weld is well below red hot. Red hot steel is some figure well north of 1000º.
Jul 12, 2016 | 01:05 PM
Yeah, 1000 degrees is when it STARTS to glow. By the time it's red it's already 1200 or more.
Jul 13, 2016 | 03:55 AM
On it's way to becoming a light bulb filament.
Jul 13, 2016 | 09:33 AM
The only one I found close to mine is for an El Camino of same vintage. This is Bull Bleep. Why can't I find one?
Jul 13, 2016 | 10:01 AM
anything like this Mustang one ?
as for the alligator clips , any autoparts store should have some .
