?Pt attached to old IVR?
I built two different styles of the "Solid State" I.V.R.
Style 1 IVR The Black wire is the 12v input, Green is ground, and the white is the 6V output.
I used a larger capacitor (than required) on the input side. This will protect against voltage surges from the alternator.
Next time I'll use a longer ground wire and less on the input and output wires.
Style 2 IVR This was a PIA. All that stuff had to fit inside, Plus I installed a LED so when it's putting out 6V the green LED is on. Pen points to LED. 4hrs to build!!!!
1963/66 F100/1100 / 1963/69 N/NT500/1100 / 1967/69 F100/750 & F800/1000 // 1971/77 Bronco // Misc 1963/69 Passenger Cars.
Great news, fuel gauge for the main (in cab) works now. So I guess the IVR was bad. I had to clean corrosion from all of the bullet connects and the female spade connectors on the plug to the tank switch. 320 grit sandpaper wrapped on a brazing rod (or drill bit) worked good. Now to do the Aux tank. It has about 30 Gal of lacquer in it now.
Jaime74656
268
09-11-2015 07:01 PM
Shadowrider123
12-13-2013 02:48 PM
Marky48170
Ford Truck Parts for Sale
01-11-2012 03:59 AM
