2017/Aluminum Bed/Box frame.... 5er Hitch????
Been away from Ford since 1988.... First new Ford and got my VIN the other day for a F350 dully. Not sure how to put it here.... Who makes a good In-Bed FWH for the new 17 that have the Aluminum Bed and Box Frame? Just trying to get it off my to-do list. Didn't order one with the truck. Been searching through the manufacturers with no luck. Am I too early or what?
Look over the Ultimate Hitches here: I LOVE mine. Light to handle and STRONG! Very quiet to run too. It is SOOO much quieter than my old Reese. I am in mid 70's and even I can move this thing in and out of the truck easily . There are a few choices here you can make.
Ultimate 5th Wheel Connection
Nice! As this being my first 5er set up for the traveling experience.... I did order the in-bed wiring, towing package etc. As far as the Goose-Ball I don't remember if it was ordered or an order Delete. Anyway, Just in case, the bed rails, can I install them or is that a Pro-Install item? I'm somewhat handy with tools. The Vidio's seem to only show the Bed Rails already installed. That is why I ask. Thanks.
I'm somewhat confused in reading this.....................First post seemed like you didn't get 5th prep, and second post seems that you did. Did you order the 5th wheel prep package?
I'd imagine that they still use the Reese Elite system and that all existing Reese Elite stuff will work. But I have yet to see a 17 like most of us, so I don't know for sure. If it is still the Reese Elite system, all you do is drop your choice of puck hitch into the 4 pucks and turn the levers 90 degrees. No tools needed.
The fifth wheel prep package includes the under bed rails with the pucks sticking through the bed for you to mount a fifth wheel hitch and gooseneck ball into the proper pucks. It also includes the in-bed 7-way electrical plug. The Andersen that Bud mentioned would require purchasing a Reese Elite gooseneck ball to drop into the center puck, then simply attach the Andersen to that. Otherwise as noted, any of the fifth wheel hitches made for the Ford OEM system will be a drop in setup with no additional effort on your part to prepare for it.
Brock Samson
Fifth Wheel & Gooseneck RV Towing
08-02-2018 10:14 AM
EricRom
04-20-2017 01:06 PM
DebbieD
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
04-18-2017 04:58 PM
Catfish_Man
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-12-2004 04:35 AM
