The continuing mystery of my 1996 F-250 PS Diesel XLT ext. cab
I crossed posted this thread to the Oregon Region and was advised I might post here as well. Any information you fellows can give me would be appreciated.
VIN# 1FTHX26FXTEA42804
So, I've been defrauded by some clown in California who sold me a truck with a clear CA title but which was really declared a loss in Oregon. Long story about how they do it, but they can, much to my chagrin! In the end, it's "a horse on me," for sure.
One of the things I've discovered besides massive front end problems, is that someone put a 5-manual tranny in this truck, which was originally built with an automatic ZF35-42 5-spd or possibly a Ford 3.03 3-spd Auto.
Does anyone know what the correct axle ratio is for the 5 spd tranny for the year 1996? And also what the door sticker tranny code would be for trucks built with the manual tranny? I don't know if there was more than one 5-speed manual tranny for this truck in 1996, but I assume just one.
The other issue is that I'm looking for a complete 4WD front end assembly for this truck (Which is why I'm posting in the Oregon section, because if anyone knows of one I can get my hands on, I will go anywhere in the state to pick it up.) The driver side axle tube on the existing one is bent and evidently affecting alignment, so I'm thinking about just replacing the whole front end out of a good truck.
Does anyone know how many model years' front ends I can use for my truck?
Of course, there's the issue of matching the front and rear axle ratios but I'll cross that bridge when I come to it. I just need a front end first.
Just my $0.02 USD worth
If any of this transaction occurred across state lines, I'm sure the California DMV and some other state/federal entities would get involved in helping rectify this issue.
If it were me, I would be calling every agency I could to get this joker. Selling a vehicle purported to be good but with a salvage title is fraud and punishable. IF the VIN on the paperwork doesn't match the cab VIN on the dash, that's a felony, if I remember right.
BTW, trans code is on the door jamb sticker along with the axle code.
Besides, I should have Carfaxed the damned truck before I bought it. I didn't based on the fact that the CA title was clean. (Let that be a lesson to everyone here. Clean titles are not necessarily clean.)
What the hell did I know? I'm just a dumb old retiree.
Anyway, my lawyer said, "Look if you like the truck, just fix it. At least at the end you'll have a truck that you know runs right! Sounds reasonable to me. I've already got all new ball joints and tie rods in it.
So, I still need the correct axle ratios for a 5-speed manual transmission.
Oh, yeah, and a new front end.
on
Sorry for your troubles ... I am surprised this was able to happen, California and Oregon are communicative states!
Unfortunately there are a lot of scum bags in this world and not enough firing squads, hangmen or lethal injections ... Exactly what they deserve!
As for gear ratio's behind a ZF5-42 (or 47), they came with several, most common is 4.10's.
And if my memory serves correct,
Trans code for ZF5 is C
Axle code for 4.10 is 45.
Someone will correct me if I am wrong.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
The second paragraph in you own quote doesn't make sense to me. You say that someone swapped in a 5 speed in a truck that originally had an automatic ZF 5 speed or a Ford 3.03 3 speed auto. Huh? The Ford 3.03 trans is not an automatic transmission and neither is the ZF. The 3.03 was used back in the 60's and 70's and would not have lasted very long behind that Diesel engine if you even find a bell housing to fit it to the engine bolt pattern.
As far as the axle ratio it could be a couple different ones. Look on the driver's side "B" pillar for the sticker that says what the trim and drivetrain code are. Then do a search to decode them.
There is no "correct" axle ratio for the ZF5. You either got 3:55 or 4:10 from the factory, that's it. You will have to look at the tag on the rear axle to know as the door code won't necessarily match the axle of things have been swapped out...
Also, u can't just pull out the auto and swap in a 5 speed, there is other things specific to each trans that need to be done as well like different PCM, the wiring harness from the trans to the PCM, the steering column has to be changed, the pedal assembly has to be changed, the gear indicator in the dash has to be changed..... It's quite the process, to do it right...
FWIW I live in MN, and own a jetta that my friend crashed and totaled, he bought it back, I bought it from him, fixed it and when I got the new title back it's clean, DOES NOT say salvage on it. I think once a salvage vehicle is fixed and sold is considered clean.
Why the hate for a salvage title anyway, I've always thought they were cheap vehicles that i knew the history of once I fixed them.
I would MUCH RATHER have a R title vehicle that was rebuilt correctly than some BEAT up POS that has a clean title. And I will also pay for for said R title vehicle as well
Originally Posted by Diesel_Brad
not if the "Rebuilt" title vehicle is in better shape than a "clear" title vehicle
That's a very valid point, but you have to weigh the cost of repairing in time and parts, against spending additional money to get a truck that was taken good care of.
In my case, I haven't that luxury. I have a truck that needs a front end. If you or anyone else knows of one in the Northwest, or for that matter a complete wreck with a good front on it, let me know. I'm interested!!
One other thing: if you buy a salvaged titled/reconstructed truck, any service bulletins and recalls are completely invalid. In the eyes of the manufacturer, that truck no longer exists!
