Older Montana question
Old 07-06-2016, 06:56 AM
Lawrencew
Lawrencew is offline
Lawrencew is a name known to allLawrencew is a name known to allLawrencew is a name known to allLawrencew is a name known to allLawrencew is a name known to allLawrencew is a name known to all
I understand there are other places to learn, but I kinda like the people on this forum so here I am. I have a 08 Montana 342PHT rear bunkhouse, are the interior walls supporting ceiling in anyway or can they be removed?
Old 07-06-2016, 08:21 AM
PlayersZ28's Avatar
PlayersZ28
PlayersZ28 is offline
PlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant future
I don't have an 08 Montana brochure but the 07 & 09 both show galvanized steel rafters supporting the roof. I would therefore assume that interior walls are generally non-supporting. They could contain plumbing and wiring runs though if you want to remove them.
Old 07-06-2016, 08:54 AM
Sous's Avatar
Sous
Sous is offline
Sous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputation
Your best bet for an answer would be in the 5th wheel towing section at the link below.
Fifth Wheel & Gooseneck RV Towing - Ford Truck Enthusiasts Forums
Old 07-06-2016, 01:04 PM
cyncwby's Avatar
cyncwby
cyncwby is offline
cyncwby has a very good reputation on FTE.cyncwby has a very good reputation on FTE.cyncwby has a very good reputation on FTE.
I'm not in any way an engineer but looking at my Montana Mountaineer I would say that none of the interior deviders, won't call them walls are not load bearing. As said by Players, the roof is supported by the steel rafters.
I would however take a look at the Montana website and look where they show the 5th wheel construction cutaway picture. That may give you a little more insight as to your question.
Obviously you could call the factory but that would be a crap shoot as to them even answering the phone or getting anyone knowledgeable enough to give you an answer. A call to a local rv repair shop would most likely get the info you need. Good luck with your rebuild.
Old 07-06-2016, 01:20 PM
senix's Avatar
senix
senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
They don't carry the roof.
You should be able to hit the manufactor website for the brochure.
As you go thru the process, the link above for the towing forums is a good source.
Old 07-06-2016, 02:11 PM
Lawrencew
Thanks guys
Old 03-25-2017, 08:40 PM
Mr-Pipeline's Avatar
Mr-Pipeline
Mr-Pipeline is offline
Mr-Pipeline has a good reputation on FTE.Mr-Pipeline has a good reputation on FTE.
What are you thinking...open up the rear to make the space more usable? I'm looking at an 2008 332PHT with the same thoughts.
Old 03-26-2017, 04:29 AM
Just Strokin
Just Strokin is offline
Just Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud of
Go to YouTube and watch some videos on rubber roof replacement on a travel trailer or a 5th wheel. This will show you how the trailer roofs are attached and supported. most have "arch" supports for the roof that supports the plywood and rubber membrane material.
This will show you that most any interior wall can be removed without a problem. There might be videos of removing interior walls.
Sailor_Roy
Montana Chapter
263
11-01-2017 10:01 AM
BBslider001
110
05-10-2017 05:12 PM
DieselCamper
Wyoming Chapter
05-21-2016 05:48 PM
WheatWhacker97
General Diesel Discussion
12-08-2015 07:07 PM
Quick Reply: Older Montana question
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
